The support/foundation for the outdoor unit of a heat pump system should be raised above the ground _____ inches or more.
What's your recommendation (try refraining from copy/pasting code). inspection flashcard #3 BEN GROMICKO InterNACHI Director of Education 'Now That You've Had a Home Inspection' Book Home Inspection Training Video on USB |
| Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Three
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
3 inches
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
1'-3"
3 was too short an answer. ha
In what state
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Good point.
It's all relative - to the state (country, county, planet) in which the property is located. Yes? BEN GROMICKO InterNACHI Director of Education 'Now That You've Had a Home Inspection' Book Home Inspection Training Video on USB |
2" minimum here in new mexico all bases are 2' tall. Not to mention need to be level.
Here on the coast of Florida, it has to do with the NGVD elevation and could be 8 feet.
Kenneth Townsend, CPI Gulf Coast Inspections Professional Inspections and Consulting Bradenton, Florida 941-779-4400 Serving the beautiful West coast of Florida "Guard Against the Impostures of Pretended Patriotism" George Washington, 1796
dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yes, in Florida you can not build below 8' National Geodetic Vertical Datum (NGVD) as one set of criteria, and if your flood zone is higher than 8 feet the ac pad must be raised proportionately. In Florida that often means that the top of ac pad should be at the same elevation as the finish elevation of the house since many many many houses are built just one inch above the required elevation based on flood criteria. I'm not 100% sure, but I believe the house pad must be 6" above the flood zone elevation, so most builders go 7" above as a safety factor. You must also maintain the 3" above grade with the ac pad.
Appliances shall be located no less than 3" above surrounding grade unless located in a flood zone at which time the FEMA flood plane maps would dictate unless said equipment meets the definition of the flood resistant construction requirements of the International Building Code Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
IRC 2006 M1403.2 Next, Inspection Flashcard #5 BEN GROMICKO InterNACHI Director of Education 'Now That You've Had a Home Inspection' Book Home Inspection Training Video on USB Last edited by bgromicko; 9/3/10 at 5:12 PM.. |
| Inspection Flashcard #3 | bgromicko | General Inspection Discussion | 7 | 8/18/10 12:34 AM |
| Inspection Flashcard #1 | bgromicko | General Inspection Discussion | 16 | 8/4/10 9:15 PM |
| Inspection Flashcard #2 | bgromicko | General Inspection Discussion | 12 | 8/4/10 12:54 PM |
