Old 12/10/10, 5:57 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is online now
Default Inspection Flashcard #9
Q: The maximum amount of fuel oil stored above the ground or stored inside a house is _____ gallons.
250 gallons
660 gallons
1,200 gallons
What's your guess?
flashcard #8
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/10/10, 6:02 PM
Brian E. Kelly's Avatar
Default Re: Inspection Flashcard #9
Zero...............
Unless you live at a Jiffy Lube of course.
Old 12/10/10, 6:05 PM
Ed Bancroft Ed Bancroft is offline
660.........................................
Old 12/10/10, 6:06 PM
You can have two 330 gal. tanks side by each in a building.
Depending on your location and jurisdiction and Heating , and fuel oil codes, you may be required to provide a containment for at least 110% of the oil contained. That usually takes affect at an amount of 500 gallons.
Old 12/10/10, 6:08 PM
Jarrod M. Northage's Avatar
Jarrod M. Northage Jarrod M. Northage is offline
660 gallons
Old 12/10/10, 7:16 PM
Kevin M. Leonard's Avatar
Kevin M. Leonard Kevin M. Leonard is offline
660 Gallons
Kevin M. Leonard
The Ohio Home Inspections Company
513-895-7700
937-283-5118
Old 12/11/10, 10:01 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
It's 660 gals, no guessing here..
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 12/12/10, 12:12 AM
pcooley pcooley is offline
Please Note: pcooley is a non-member guest and is in no way affiliated with InterNACHI or its members.
660 gallons
Old 12/12/10, 8:13 AM
Wayne B. Wilson's Avatar
660 gallons
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 12/12/10, 9:38 PM
David G. Lightner's Avatar
David G. Lightner David G. Lightner is offline
660 gal
Edison, NJ 08817
(848-565-7741)
Inspection Flashcard #8 bgromicko General Inspection Discussion 7 12/10/10 5:52 PM
Inspection Flashcard #7 bgromicko General Inspection Discussion 7 10/5/10 6:05 PM
Inspection Flashcard #6 bgromicko General Inspection Discussion 4 9/21/10 3:18 PM
Inspection Flashcard #5 bgromicko General Inspection Discussion 13 9/9/10 6:14 PM
Inspection Flashcard #4 bgromicko General Inspection Discussion 12 9/3/10 4:07 PM
