Old 6/15/07, 6:18 PM
jmondragon jmondragon is offline
Please Note: jmondragon is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Inspection of Manufactured Homes
I have my first Manufactured Home to inspect next week. Is this type of home inspected like a regular home?. What are the main points to take in account and are different from any other regular homes. What about price? Shall I use the same price scale actually being used? Any advise would be greatly appreciated.
Old 6/15/07, 6:37 PM
lcapaul's Avatar
lcapaul lcapaul is offline
Please Note: lcapaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Inspection of Manufactured Homes
Jorge, Try this site for information. I consider the Manufactured hom inspection to be quite a bit different than a normal home, Tiedowns, supports, skirting, PB Plumbing possibilities, different construction method.s, myself I charge abut $50 more.
http://www.inspect-ny.com/structure/...nspections.htm
Old 6/15/07, 7:05 PM
Thanks Lewis. Awsome information to study during the weekend.
Old 6/15/07, 7:34 PM
Doug Edwards's Avatar
In the State of Florida the foundation; tie-downs, piers, LSD's, etc. has to signed off by a licensed engineer. It's the law! You need to inform your client of this. The home inspector can not do this unless he/she is an engineer. Florida has some very strict guidelines for MH foundations. We have to, things blow away here.
Old 6/15/07, 7:39 PM
lcapaul's Avatar
Does that need to be done with each sale or transfer of property, to ensure that things have not been "Modified" by the seller, or does just the "paperwork" need to be verified?
Old 6/15/07, 7:46 PM
Just what you said. Sale or transfer, refinancing, etc. There is a very detailed set of instructions and guidelines. (HUD, FHA, VA and FLorida). "Modified" is a good word. That is a kind word for what some people do (or don't do).
Old 6/15/07, 8:05 PM
Brian C. Hoagland Brian C. Hoagland is offline
As has been stated the tie downs and foundation portion of an inspection of a mobile home in fla. is not something the home inspector can do. The client should be apprised in writing of this as a part of the report. Other than that it is like a normal inspection- find and list defects. Things like polybutylene piping and ductwork on the floor of the crawlspace getting wet and vapor barriers having penetrations and windows leaking causing the floor(particle board) to swell and loose it's integrity-etc. are not normally found in normal everyday home inspections but are common in manufactured homes(trailers). If you should find a defect in strapping or tie downs or foundation piers refer it to an engineering or Installation firm. I work for one but this ain't an ad for me.
Old 6/15/07, 8:24 PM
Thought of a few more things you might want to take a close look at: Ventilation of approx. 1 sq. ft per 150 sq. ft. of floor area, Rodent proofing: no holes greater than 1Sq. in., No additions to be partially supported by mobile home framing after 2005. In older homes if gas or oil heat was discontinued, are there any buried tank installations? If the poly piping was removed and retrofitted, did they get it all? Did they properly reinstall the Vapor barrier? I said before it was like a home inspection and it is. It just isn't the same kind of home.
Old 6/15/07, 11:51 PM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
Brian...could you explain further the 1/150 ventilation?
Old 6/16/07, 8:28 AM
That's what they want down here for crawlspace venting on a manufactured home a 20x 50 home (1000 sq feet) would require skirt vents to allow 6.67 square feet of opening. 1000 divided by 150. Either that or 200 sq. inches for every25 horizontal feet of skirting.
Old 6/16/07, 10:26 AM
dharris dharris is offline
Please Note: dharris is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's OK.... in Fla. to have an addition partially supported by MH framing on homes prior to 2005?
Old 6/16/07, 10:40 AM
gbeaumont's Avatar
Hi Dan, no it is not. as manufactured homes are engineered structures no further loads can be put on the structure unless engineering approval is sought, personally I teach that any and all additions (porches, decks & Carports) should be free standing structures, and if they are not then to write them up as non conforming.
BTW, some manufacturers now include engineering drawing for things like deck and porches with the original plans and installation instructions, if a porch or similar is attached it should be done to the manufacturers specs.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 6/16/07, 2:03 PM
Today, I had the opportunity to preview this manufactured home I'll be inspecting and the crawl space is totally inaccesible. It is nailed with boards. Could not see anything under the MH. How shall I report this? An Doug, thank you for the information about ties downs and foundations needing to be signed off by an Engineer. I did not know that and I'll apprise my client on the report.
Old 6/16/07, 2:15 PM
[QUOTE]
The items to look for, and common defects identified by others, are just a tip of an iceburg of defects found under a MH.
You would be a fool to do the inspection, and disclaiming the crawl space.
Old 6/16/07, 2:24 PM
Jorge,
You are more than welcome. If there is a Realtor involved they should know this about the requirement but I still run across one every once in a while that doesn't. If it isn't accessible you really need to take numerous photos showing this. It would do you little good to just spot check a MH foundation taking into consideration all the plastic piping inherent in them. They are very prone to leaks and you will want to know if any of the plumbing fixtures are leaking into the flooring. The flooring in most MH is particleboard and turns to mush in no time when it gets wet. Any bathtub enclosures I always open up to look inside. Find lots of leaks there. If you have any questions give me a call and I will be glad to help out in any way one on one.
Learn the Differences: Site-Built, Modular, Manufactured/Mobile Homes jsieg General Inspection Discussion 10 12/22/07 11:20 PM
Toxic Gas in Mobile Homes jbushart Miscellaneous Discussion for Inspectors 0 11/12/07 8:31 PM
Grab Your Checkbooks - For sale: 2 million empty homes jburkeson1 Miscellaneous Discussion for Inspectors 2 10/26/07 7:22 PM
Water heater strapping in manufactured homes ilpowell Plumbing Inspections 10 2/24/06 5:20 PM
