I was contracted to do some remodeling work on a house, sanding painting etc., when the owner found I was a home inspector he asked for a home inspection. We are not supposed to use inspections to generate secondary work but what if it happens the other way around?
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I'd say you can't work on any component you haven't already contracted to do after the inspection.
"Total conflict of interest". |
Check you private messages...
Also please edit your profile so we know where you are from. You'll get many more responses if you do. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
id say do it.
If you did it wrong, you will not be able to report that you did it incorrectly since you did not know how to do it in the first place!!! |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
We all know that contractors take shortcuts on certain things,and nobody will admit that about themselves. "Darn pipe angle made me use plumbers putty" |
IMO if your doing the work then you shoud pass on the HI....
You should not inspect work that you have performed...
And... You should not work on what you have inspected. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Ditto
If all you did during the remodeling of the house was sand and paint...why not???
Now if you had performed other tasks that would fall under your associations SOP's....NO WAY!!! www.buildingcenter.org Quickly determine the date of manufacture, age or production of most HVAC and Water Heating equipment |
| Question for all... | Bob Hopton-Jones | General Inspection Discussion | 9 | 4/6/07 7:43 AM |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/20/07 11:56 PM |
