What guidelines do most of you follow when conducting inspections of refrigerators? Thanks, in advance for the advice.
1. open door
2. insert hand 3. if it feels cold.... it works. |
Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
4. open freezer door
5. insert hand 6. if it feels even colder, it works seriously, generally i use my infrared thermometer to make sure the fridge and freezer are around the appropriate temps. 40 or so for the fridge and around 0 for the freezer....give or take a few. |
Same thing I do. But now it does not work three weeks later, and they want a new one.
Insert hand and feels cold works for me. JMO Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
sure it depends on setting....but if i get a temp reading in the fridge of 60 degrees and the temp is set at 40, then there is a problem. but generally, the "hand method" works just fine.
was it working when they moved in or did they close and then realized it wasn't working?
Did they do a pre-closing walkthrough? ************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
I just get the temps, check the door seals and if there is an ice/water dispenser I see if it works.
We don't do refrigerators, washers, dryers, portable dishwashers, window A/C units, etc.
I carry two thermometers with me. I put one in the refrig and one in the freezer. I snap a picture of both of them. If they are not within normal temps, I check the settings. If they are not set to manufacturers specifications, I recommend that that re-set them and check the temps prior to closing. If they dont reset, service or replacement is recommended. It the controls are set properly, and the temps are off, I recommend service or replacement (depending on age). I also check the door seals and ice maker.
Give them this: Sale at Best Buy
1-6 of 6 matches for "Refrigerators" Show me: -- Select a Sub-Category -- Side-by-Side Refrigerators (2) Sort by: Price Title End Date Brand $1499.99 thru Jan 13 LG 25 cu. ft. 3-Door Black Refrigerator with Icemaker #7755137 $1199.99 thru Jan 13 LG 26 cu. ft. Side-by-Side Titanium Refrigerator with Ice/Water Dispenser #7622478 More information $1099.99 thru Jan 13 Whirlpool® 25 cu. ft. Side-by-Side Stainless-Look Refrigerator #6346723 More information $899.99 thru Jan 13 Whirlpool® 25 cu. ft. Side-by-Side Refrigerator with Ice/Water Dispenser #7968782 More information Reg. $869.99 $799.99 After $70 Savings thru Jan 13 Samsung® 18.8 cu. ft. Refrigerator with Bottom Freezer #7033809 More information Reg. $449.99 $429.99 After $20 Savings thru Jan 13 Frigidaire™ 18 cu. ft. Refrigerator with Top Freezer #7034513
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County Last edited by sstanczyk; 1/13/07 at 9:18 PM.. |
I Tell My Customers ( Right After They Sign The Contract ) That All Appliances That Are Checked Are Working Fine That Day, Unless Otherwise Noted!
I check the range for anti tip, I check the DW on 1 cycle other than that I wright down serial #'s for recall, but that's it. Oh ya I check permanantly installed microwaves for functionality.
