The life of a roof depends on local weather conditions, building and design, material quality, and adequate maintenance. Slate, copper, and clay/concrete roofs have the longest life expectancy while roofs made of asphalt shingles, fiber cement or wood shakes will fail sooner.
ROOFING YEARS Aluminum Coating 3-7 Asphalt Shingles (3 - tab) 20 Asphalt (Architectural)30 BUR (Built-up Roof) 30 Clay/Concrete 100+Coal and Tar 30 Copper 100+ EPDM (Ethylene Propylene Diene Monomer) Rubber 15 - 25 Fiber Cement 25Modified Bitumen 20 Simulated Slate50 Slate 50+ TPO7 - 20 Wood 30 How about metal roofing??? And what is TPO???? Thanks in advance. |
| Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Those may work up north, but here is Florida the life expectancy is much less
Thanks for the info.
Still, why no metal roofing? |
Metal roofing lasts really long, much longer than asphalt.
Yeah, I know. My main question is why isn't it on the chart? Metal is a pretty common and popular roof covering, that seems to me, should be listed as well. I've kind of incorporated some of these into my reports and was just curious.
If you can find me some reference to how long they last, I'll get it in there.
Most metal roof manufacturers will give a warranty of around 45 to 50 years.
http://www.metalroofingwholesalers.com/ |
i can get some info give me a few days.....some metals are life!!!! Comps also now have life warranties. |
The tpo I install has 10,15, 0r 20 yrs 10 is 45 mil 15 is 50 mil 20 is 80 mil |
meduim shakes are rated at 20 at the most heavys will be 30 alm coating comes in 5,7, or 10 yrs. however if its not installed correctly more like 2-3 years I SEE THIS ALOT! most guys just roll it out and it dont stick! the deck has to be cleaned and washed before you can roll out coating.....1 thin layer then one heavy coat.....just so you guys know. |
you also have 25 yr comp....now is rated at 30. there is also 30,40,50 yr comp. out there some of the higher end comps are now giving LIFE WARRANTIES... |
I have yet to see a wood roof here in KC last more than 20 years, no matter what the thickness. Average here is 17 years for wood; winters, summers too harsh.
When you see the shingle quoted as a 20, 25, 30, 40 or lifetime shingle that denotes the warranty period. The part that people do not understand is that the warranty is against defects in materials only, not the lifespan of the shingles. Here in Florida the average lifespan of a 25 year shingle is 12-14 years under normal weather conditions. A 30 year Architectural shingle will last 16-19 years. 25 year shingles come with a 60mph wind uplift warranty, 30 year shingles come with a 80mph wind uplift warranty although some of the newer ones come with a 110mph wind uplift warranty when installed by a certified roofing contractor and useing 6 nails per shingle. Florida code was 6 nails per shingle for a while but has since been reduced to 4 nails per shingle. 40 year shingles generally carry a 110mph wind uplift warranty, while the 50 year/Lifetime carry a 130mph wind uplift warranty. Sorry for the lecture but maybe it will help clarify things.
| Before You Start Repairing or Replacing Roof Finishes from CMHC | mkyriacou | Canadian Inspectors | 0 | 9/17/09 12:52 PM |
| Please post questions about anything having to do with roofing | kshepard | Exterior Inspections | 165 | 6/17/09 11:47 AM |
| Imagine There's A Heaven | jmckenna1 | Miscellaneous Discussion for Inspectors | 3 | 12/23/07 11:15 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Equipment Life Expectancy Chart | ekartal6 | Miscellaneous Discussion for Inspectors | 2 | 10/31/06 9:39 AM |
