Old 10/21/11, 11:09 AM
Joe Fleet Joe Fleet is offline
Default ICC Certification
Anyone have ther R5 certification as a Residential Combination Inspector? If so, do the exams in the (4) areas (B1, E1, M1, and P1) have to be done at the same time, or can they be done in succession? Any time requirements? Also, what do you think is the best way to prep for the tests?
Appreciate it.
Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/21/11, 11:59 AM
rspermo rspermo is offline
Please Note: rspermo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: ICC Certification
I am an ICC Residential Combination Inspector. I took two tests in one sitting (4 hours total). Passed all 4 on the first attempt but I am a good test taker (does not mean that I am an expert on the subject matter!). The tests are really an exercise on if you can find the answer (information) in the code books. I do not believe they expect you to know the books completely. I studied by reading alot of the IRC. Then I became very familiar with the Table of Contents, the Index and the basic content of each chapter. Good luck! I have made money I would not have made by being an ICC Residential Combination Inspector.
Old 10/21/11, 12:13 PM
Nick Gromicko's Avatar
http://www.nachi.org/residential-cod...-exam-prep.htm
http://www.nachi.org/commercial-code...-exam-prep.htm
http://www.inspectoroutlet.com/inter...ash-cards.aspx
Find a Home Inspector
Old 10/25/11, 11:50 AM
Thank you both.
Old 10/25/11, 6:28 PM
ICC exams are open book, so given enough time, everyone would score a perfect 100. The key to passing ICC exams is to understand that they're really just speed tests. You have to know the answers to enough questions so that you end up with enough time to answer the ones you have to look up. It's basically that simple. See my links in post #3 of this thread. Those links will get you to the point where you can answer enough questions correctly without having to look them up in the book, so that you end up with a couple hours to look up the rest. And you don't even have to do that, I think you only have to answer a little more than 2/3rds correctly to pass.
Anyway, it helps if you understand that ICC exams are in essence... open-book speed tests.
Old 10/26/11, 3:42 AM
Joe -
I've been BOCA, ICBO and currently ICC certified as: electrical, plumbing, building, mechanical and combo.
For my own peace of mind I took each of the 4 as a stand alone. Worked nicely. Studied for 1 week - took test. Studied for 1 week - took test.
Tab your code book AND know where stuff is.
Old 10/26/11, 8:49 AM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
Originally Posted by dbowers View Post
Joe -
I'm certified also (BO in SC). I agree. Tabs are essential. You can buy them from the ICC.
Also, I had the binder cut from my book, had holes punched in the pages, and inserted the pages into a ring binder. If you ever get tip sheets, etc. you can stick them right in there. Be aware that the test agency will not allow you to insert anything other than the book however. Be careful.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 10/26/11, 11:38 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
I tried to pass but I had to think just the opposite of safety and train my brain to accept MINIMUM CODE MINIMUM CODE MINIMUM CODE.
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 10/26/11, 12:06 PM
Also, the key that comes with the tabs that tells you what page to put each tab... is not permitted to be in your book when you take the test. Only the tabs are. Been there, done that.
Old 10/30/11, 11:48 AM
Our code guys gave me a clue about the KEY (the key that comes with the tabs that tells you what page to put each tab... is not permitted to be in your book when you take the test).
They suggested gluing it onto one of the rear pages with USELESS ads about ICC on the page. I did - the proctor never said a thing.
CAHPI National Letter rcooke Canadian Inspectors 10 1/14/11 12:41 PM
Washington State Inspectors - Your Deadline Is Near Mike O'Handley Legislation, Licensing & Legal Issues for Inspectors 54 4/14/10 9:15 PM
ASHI's Latest Scam to Dupe the Public jbushart General Inspection Discussion 10 1/16/10 11:43 AM
CAHPI Discussion Board rwand1 Canadian Inspectors 6 6/14/06 8:34 AM
From the Tattered Little Date Book rwand1 Canadian Inspectors 20 5/15/06 12:03 PM
