Page 42 of Feb 2010 JLC - in the article - "Why You Shouldn't Exhaust the Bath Fan in the Attic".....a plumber discovers mold in the attic and refuses to continue his work.
Insurance company has the owner call a certified forensic hygeneist who identifies the mold as Stachybotrys chartarum and the hygeneist recommends remediation that, in all, will cost the home owner $20,000. The homeowner contacts a builder. The builder investigates and finds the mold limited to the area at the end of the bathroom fan exhaust duct laying on the floor of the attic and recommends that it be cleaned up with soap and water. The story has the happy ending with the builder saving the owner $20,000 and the "certifiable" hygeneist standing by his report. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I was reading that this morning James. I am sure they will get lots of letters to the editor on that one....
Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
That is why grandma used to keep Lye soap around the farm. Kills everything and leaves it clean, bug and germ free. The old timers knew things, had remedies and cures for things modern science is still wrestling with. She only lived to be 99 and would probably still be alive had she not been put in a nursing home where she fell and broke her hip. Her mother (my great gran) was well over 100 when she passed. They were simple folks with tremendous common sense.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill Last edited by dedwards; 2/14/10 at 9:15 PM.. |
The Journal of Light Construction? What do they know about mold? If I was the Industrial Hygienist I would stand by my report too. If it would ever go to court, the builder would lose because there are actual standards for removing mold for a reason.
You can clean mold with soap and water but if the wood needs to be sealed or the mold will just grow back. I have seen it in a hospital that was in the Flood of '93. Also the cleanup needs to be under negative air to control spore drift in the living area, so on and so on. Most of my mold jobs deal with insurance companies and builders not cleaning up mold the right way and the occupants getting sick. Sad but true. |
I would go with the hygenist.
I see all kinds of "contractors" around here who, dealing with the hard times, go into mold cleanup. Some use soap and water and some use bleach (both are wrong) and, for some inexplicable reason, cannot be found when the problem comes back. Curious. ain't it. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
It would be interesting to have a second IH go back after the repairs were made and examine the home without being privy to the original findings.
I guess when the subject of clean up got started, no one thought to mention that unless the moisture / water problem is dealt with the mold is going to come back no matter what you use. Most of the mold problems we see are relatively small and fall well below the EPA standard for self clean up but I always tell the customer that if they do not correct the moisture problem they can forget about curing the "mold problem".
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Now that I did not know, but thanks. I will file that one away.
Exhaust fan into attic = $20k in remediation efforts?
For a small amount of mold? We're kidding here, arent we. The remediation and testing industries are going to burn themselves out of existence. |
same here.
http://homerenovations.about.com/od/...oldprocess.htm |
The article is missing a great deal of info, mainly if you do not remove the mold growth, the sealer will not stick and just peel back off.
The little bit of visible mold, usually after closer examination winds up being a lot of mold. Sad but true! |
| Mold Remediation | Giovanna Bl | Ancillary Inspection Services & Additional Topics | 8 | 2/28/09 12:34 PM |
| CMI imposter? | jbraun | Certified Master Inspector (CMI) Discussion | 118 | 11/26/07 4:55 PM |
| The debate goes on and on | cbottger | Ancillary Inspection Services & Additional Topics | 3 | 11/10/07 9:06 AM |
