To fill my dance card, I have taken on inspections in the foreclosure market. This requires accessing vacant homes without a key and changing the entry lock out. There are lock pick tools, pick guns, bump tools, cylinder drills, ect. Any suggestions of what’s going to be the fastest and easiest?
Bob Drew bob@cstonecci.com |
So...your doing the lock picking, changing the lock, and doing the inspection? Isn't there something in our COE that prevents us from doing any work on the properties we inspect?
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
There was thread not too long ago on "bump keys" you can either make yourself or buy off the internet. I believe Will Decker is the one who posted it but not sure.
I'd have to re-read the COE to get the technicalities of this, but I don't see any problems with this. A lock isn't a defect. In a sense, I would put this in the same category as inadvertantly causing damage to the home during the inspection, then repairing that damage. No conflict of interest. Therefore it still meets the "spirit" and "intent" of the COE if not exactly the "wording" of it. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Robert, I do several of these a week; one of the best things to use is a pair of slip joint pliers; put it on the outside of the door knob and push your weight into it; most doorknobs will crack instantly; then you remove the screws and replace.
You can buy the set of Bump Keys online like was mentioned by Doug. I bought a set last year to help the private school I do consulting for remove student locker locks at the end of the year. Some of them work amazingly easily. I also wanted to make sure I couldn't bump my own front door.
2008 InterNACHI Member and Innovator of the Year HOME INSPECTOR PRO HOME INSPECTION SOFTWARE NOW ONLY $499 ($15O OFF!!) Easy to use, customizable Home Inspector Software that runs on Windows, Mac & Linux InterNACHI members receive 3 months of FREE home inspector website hosting List yourself in our Home Inspector Directory Free Watch our NACHI.TV Software & Search Engine Optimization videos! Help@HomeInspectorPro.com |
Bob its called a foot Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
I used to get locked out tenants back in all the time.
I would know where to drill into the deadbolt in order to shear the pins on the cylinder |
Deadbolts suck, now door knobs are just plain easy. That is why I will always lock my doors with the dead bolts.
I can open a dead bolt in less than 30 sec.
Locks are made to keep honest people honest. |
ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 561 5327 office 613 929 9919 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
Doorknobs use a pair of channel locks. Drill is the quickest most sure way through a deadbolt. These usually aren't inspections, but rather condition reports for the bank taking back the property, but take plenty of pictures to cover your arss
Steve Radabaugh Preferred Property Inspections Columbus Ohio Home Inspection Ohio Home Tips Westerville, Ohio |
dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
If it's just a doorknob a sawzall works wonders in seconds!! Just cut the knob right off and wah-lah, you have access.
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| Electrical Guru Question? Breaker lock outs | pdoane | Electrical Inspections | 4 | 9/7/07 3:05 PM |
