What type duct material is typically used for a stove/ range down draft vent? I recently had one that was connected to a plastic dryer vent duct material in the crawlspace. Don't think that's right
What I have seen is a metal close-accordianed type that can be bent to the different angles needed. The big box catalog calls it 'semi-rigid aluminum vent duct'.
The plastic dryer vent type wouldn't do well, at all. Course, be cheap to do spring cleaning. Just toss and replace !! |
LOL! Thx Linda! Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Home Inspection Reports Powered by: HomeGauge eServices |
IRC SECTION M1503
RANGE HOODS M1503.1 General. Range hoods shall discharge to the outdoors through a single-wall duct. The duct serving the hood shall have a smooth interior surface, shall be air tight and shall be equipped with a backdraft damper. Ducts serving range hoods shall not terminate in an attic or crawl space or areas inside the building. Exception: Where installed in accordance with the manufacturer’s installation instructions, and where mechanical or natural ventilation is otherwise provided, listed and labeled ductless range hoods shall not be required to discharge to the outdoors. M1503.2 Duct material. Single-wall ducts serving range hoods shall be constructed of galvanized steel, stainless steel or copper. Exception: Ducts for domestic kitchen cooking appliances equipped with down-draft exhaust systems shall be permitted to be constructed of schedule 40 PVC pipe provided that the installation complies with all of the following: 1. The duct shall be installed under a concrete slab poured on grade; and 2. The underfloor trench in which the duct is installed shall be completely backfilledwith sand or gravel; and 3. The PVC duct shall extend not more than 1 inch (25 mm) above the indoor concrete floor surface; and 4. The PVC duct shall extend not more than 1 inch (25 mm) above grade outside of the building; and 5. The PVC ducts shall be solvent cemented. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Draft fan & gravity vent | rbrady | Inspecting HVAC Systems | 7 | 1/4/08 8:19 PM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
