Old 8/4/08, 7:34 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Default Ladder Help
Anyone out there using this ladder? Pro's and con's? Thanks.
Werner Ladder
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 8/4/08, 7:41 PM
Default Re: Ladder Help
Werner Ladder
Hi, Ian. I've had that ladder for 2 - 3 years. It's a little heavy but I've used it for some high roofs.
Mostly it sits in the garage and is used to clean out the chimney at my place since I bought the Extend and Climb 15.5 footer. Usually I can get where I need to with the 15.5.
Larry Kage, CMI
231 929 3525
Old 8/4/08, 7:46 PM
Bruce A. King's Avatar
I like this 12 ft one, fits in my trunk and easy to get upstairs for attic scuttles etc.
http://www.acehardware.com/product/i...ductId=1904119
www.BAKingHomeInspections.com
704 301-3207
Old 8/4/08, 7:46 PM
Frank Magdefrau's Avatar
Frank Magdefrau Frank Magdefrau is offline
Bulky and heavy but great to have. Just make sure you also carry a light weight ladder(s) as well.
Frank Magdefrau
DeSoto Home Inspection Services
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
InterNACHI Member since 2002
InterNACHI message board member since 2003
InterNACHI ESOP member from 2004 to 2010
Old 8/4/08, 7:47 PM
Peter Doane's Avatar
Ian,
I believe this Warner is a knock off of the Little Giant. I have been using the little giant ladder ever since I started and love the ease of use and safety.
Peter Doane
NACHI ID# 05120681
Old 8/4/08, 7:54 PM
mivie's Avatar
mivie mivie is offline
Please Note: mivie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Go to Lowe's and look at the one's they have. Mine is made by Cosco. I have worked off ladders all my life and these are the safest ones I have found. Yes a little heavy but I am very comfortable on it. Lowe's and Sam's Club have them for around $100. The 14 ft fits nice in a trunk.
Old 8/4/08, 7:56 PM
James E. Braun, CMI's Avatar
I have a 17 foot one. The reason why I did not go longer is because I use for accessing attics also. I should had bought one years ago.
Old 8/4/08, 8:42 PM
jmcmahon's Avatar
jmcmahon jmcmahon is offline
I use that ladder a little heavy and bulky to carry inside, but sturdy. I like it just the same.
Jeffery M. McMahon
Williamson, Ga.
Old 8/4/08, 8:46 PM
ldapkus ldapkus is offline
Agree. It's bulky and heavy.
Old 8/4/08, 9:51 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
I started with the 17 footer and wasn't able to hit most roof in my area. I then went out and got the 22 footer. It's heavy and awkward, but I can hit most roofs in the suburbs now or at least get to the eaves. It's pretty versitile too it you buy the extra scafolding brackets. For really tight attic hatches, I take the wider extension pieces off and am able to fit in much tighter spaces. Don't think you are going to do much roof to roof hopping with this beast. I had to pull it up onto a second story roof once. Never again!
I am looking for a lightweight 3 sectional fiberglass ladder to hit the high roofs here in Philly.
Old 8/4/08, 10:34 PM
cfuoco's Avatar
cfuoco cfuoco is offline
Please Note: cfuoco is a non-member guest and is in no way affiliated with InterNACHI or its members.
Lowes has them cheaper than the price on the website you posted.
Old 8/4/08, 10:41 PM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Werner Ladder
I've had the 17' version for 2 years now without issues, that being said you can pick up the 22' ladder cheaper http://www.lowes.com/lowes/lkn?actio...-22&lpage=none
Old 8/4/08, 10:53 PM
Carl A. Brown's Avatar
I have 4 little giants that I used when I was doing stucco.
The are heavy but very safe just like the others have stated.
BK could probably fall off one tho!
Old 8/4/08, 11:10 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
I've got 2 ladders. They've gotten me everywhere I need to go.
The LG (22') was a little pricey but well worth it.
The Costco knockoff (about 12') was only $96.00 at Wal-Mart about 7 years ago. It's the one that goes in the house for attics when necessary. It also gets me on about 90% of the roofs. The LG takes care of another 5% and then there's the 5% I just don't get on. IF I had to have only one ladder, it'd be the Costco knockoff.
Old 8/4/08, 11:18 PM
iniquette's Avatar
Thank you guys. Lots of great replies. So, to refresh here. I personally do need the 22 footer for some other work that I do. And several of you have stated that I can get it cheaper at Lowe's. sounds good, thanks again guys, I appreciate it very much.
Ian Niquette
Markesan WI 53946
Active Rain Network
Climbing up a ladder today kswift General Inspection Discussion 31 12/27/06 11:48 PM
Ladder Safety from ITA badair General Inspection Discussion 4 8/9/06 7:59 PM
Ladder safety by Rick Bunzel gbeaumont Miscellaneous Discussion for Inspectors 9 3/24/06 6:24 PM
