Old 10/1/09, 9:21 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
Default Ladder Safety. Please proof this new inspection article.
http://www.nachi.org/ladder-safety.htm
Find a Home Inspector
Find an InterNACHI certified North Dakota Home Inspector (and anywhere else in North America)
Old 10/1/09, 9:40 PM
Default Re: Ladder Safety. Please proof this new inspection article.
Nice Nick, we can never be safe enough in a ladder.
Maybe we should all add this as part of the ladder accessory to make them safer.
Old 10/1/09, 11:28 PM
Stephen W. Stanczyk's Avatar
In the first section for telescoping ladders....
I think it would read better if the words "be aware" were used instead of beware. By using beware, it feels like an opinion has already been imposed by the writer instead of supplying information and letting the reader make up their own mind.
JMHO
Stephen Stanczyk
Old 10/2/09, 12:26 AM
Bob Elliott's Avatar
he distance of non-self-supporting ladders from the structure. This type of ladder must lean against a wall or other support, so they should be positioned at such an angle that the horizontal distance from the top support to the foot of the ladder is about 1/4 the working length of the ladder. A rough method to test this angle is by placing your toes at the base of the ladder and stretching your arm. Your hand should just touch the ladder;
I
would mention stretching is done at shoulder height .
When I took two different ladder training courses i was taught to slightly bend the elbow and grab the rails for proper angle.
Most fiberglass ladders also have a small l shaped icon on the rail that will go perfectly vertical (straight up and down) when the correct angle is placed so that guess work s not needed.
I also recommend claws at the bottom to dig into ice and dirt to prevent slippage.
Old 10/2/09, 11:45 AM
Rob London Rob London is offline
Originally Posted by belliott View Post
I[/B] would mention stretching is done at shoulder height .
Done. Can you post a link that has more info about the vertical icon? Sounds interesting.
Done. thanks guys
Researcher and Technical Writer, InterNACHI
Old 10/2/09, 12:02 PM
Patrick Bolliger's Avatar
So Bob are you going to buy another ladder now??
That fold up Warner er Werner is a scary beast.. Talk about loose joints and height?
The longer they get the "looser" they feel.. Cheap ladder are expensive in other way... HOSPITAL vist...
Old 10/2/09, 12:18 PM
That"s why I am going to be using the Aerostar once snow hits.
Double insurance on the car beats cost of hospital visits.
I truly hate multi-ladders.
Old 10/2/09, 12:38 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
I would add that when using fiberglass ladders to check for cracks in the fiberglass before using a ladder. Can be a problem, especially if you use your ladder in cold weather.
Also, when using an extension ladder be sure that you can handle it safely by yourself to avoid accidents and injury. If you need a longer ladder, you will need someone to help you manuever it also.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 10/2/09, 1:15 PM
Done. thanks guys
Rob
I pulled my van out of the garage to get to my fiberglass ladder (started after sitting all summer)(92 Ford Aerostar).
Feel bad because the darn sticker is peeled off.
Ok now I feel like a lier and do not see a picture of it anywhere on the internet ,so I will go to the store and take a pic to save face.
Meanwhile here is a great Power point on ladder safety.
http://www.uwm.edu/Dept/EHSRM/TRAINING/LadderSafety.ppt
Old 10/2/09, 1:48 PM
Here you go Bob. I was taught the same way as this and never had a problem.
Forgot the link.
http://www.rd.com/advice-and-know-ho...cle117162.html
Old 10/2/09, 1:49 PM
iniquette's Avatar
Is that yo in your younger days Marcel? Nice mop.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 10/2/09, 1:52 PM
My Father would have shot me to have hair like that during the hippie era.
Old 10/2/09, 2:09 PM
Forgot the link.
Does not show the sticker.
Old 10/2/09, 2:12 PM
Damn, your demanding Bob. It's on the other side of the ladder.
Old 10/2/09, 2:35 PM
Mark S. Tyson Mark S. Tyson is offline
Originally Posted by gromicko View Post
most people always wonder what is leaning to far on a ladder? i would like to see that defined. the last saftey course i took the osha instructer cited the belt buckle rule. meaning that your belt buckle shall not pass outside of the rails of the ladder
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Ladder Safety Extensions mcyr Miscellaneous Discussion for Inspectors 3 4/6/09 10:10 AM
Please proof this article: Dryer Vent Safety gromicko Interior Inspections 2 4/1/09 6:33 PM
Ladder Safety from ITA badair General Inspection Discussion 4 8/9/06 6:59 PM
Ladder safety by Rick Bunzel gbeaumont Miscellaneous Discussion for Inspectors 9 3/24/06 5:24 PM
