What is your opinion of this?
Is this dangerous and illegal? Is this legal, but still dangerous? Is this not really a big deal at all? |
| Find an InterNACHI certified Kansas Home Inspector (and anywhere else in North America) |
It will never get changed anyway but you will have made our client aware of the potential problem and your reason for concern. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Wayne,
Please go and edit your profile to include your location. It will help all of us to give you the best answer. I see you are in Ontario but I had to reverse look your phone number to find that out. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Thanks Michael. I will do that.
As for the picture. My concern is not of the limited space. My concern is that the electrical panel is directly in front of water. |
I agree this is NOT the best place to place a washtub. When I see this I usually recommend that there be a cabinet door installed over the top of the panel, to limit "spraying"
With the panel and enclosure door in place I don't see the issue.
The code violation is workspace requirements but I never site code as I am not an AHJ. Perhaps another Ontario inspector can give you a more local flavored opinion. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
cboyd is a non-member guest and is in no way affiliated with InterNACHI or its members.
Had one 2 weeks ago, almost exactly the same and wrote it up just as Mr Larson stated,
Would you take the dead front off this panel or would you say it was unsafe or in an inaccessible location?
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
I've taken them off with less clearance than the one shown but it's a judgment call.
Put your personal safety first when deciding. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
It doesn't meet requirements for accessiblilty. Don't quote code until pressed on the issue, but I think the rquirements are 15" clearance to either side and nothing to floor and 36 of nothing in front. Don't make reccommendations regarding cabinetry installations as has been suggested that would violate the code too. As for the safety issue with regard to the sink, I don't think it matters as the only way to correct the other issue is to remove it or move the panel.
Here ya go...
There is no safe way to work and repair this panel, and could pose a hazard to either the occupant or a licensed electrician. Although not our job to cite codes, it can be mentioned that it does not meet the existing standards for a safe useable, accessible, and repairable installation, and may pose a danger to all that need access to this panel. This installation might not even have been acceptable at the time it was installed. Safe workable clearances around electrical panels have been around for a long time. AHJ' are not always privy to some of these safety issues and code standards in a lot of jurisdictions, and are exempt of being held liable for their mistakes. We are not. Make your concern in black and white. Good find. JMO Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I could just stand in the tub and take the dead front off,
Micheal is right, it won't get changed, but it might need repair. I would definitely try to see inside the panel. The problem can be corrosion, steam rising from the sink and condensing on the cold metal. Even worse if there's a dryer below the panel.
John Kogel www.allsafehome.ca |
| Are you scanning electrical the panel | cbottger | Thermal Imaging, Infrared Cameras & Energy Audits | 4 | 8/16/08 12:47 PM |
| Electrical Safety Foundation International Links | jtedesco1 | Electrical Inspections | 5 | 12/8/07 3:10 PM |
| Wrong screws on panel front | kgraham | Electrical Inspections | 12 | 4/5/07 5:26 PM |
| City electrical inspector says move the meter and panel | cbottger | Electrical Inspections | 9 | 4/4/07 8:59 PM |
