Old 7/23/12, 12:39 PM
jashley's Avatar
jashley jashley is offline
Arrow Little Giant Pro series Ladder
Does anyone use the little giant pro series ladders? I've always used the standard fiberglass extension ladders. I'm thinking of changing my company van to a smaller one possibly to a HHR cargo. Not sure about just yet though. Anyways, how does the ladder feel as far as getting up there on a 2 story roof? I was looking at the 26 foot little giant pro black series. Its traveling height is 6.5 feet. about 54 lbs. My fiberglass Werner 24ft is 59.4 lbs and needs to be on the roof of my Express Van.
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/23/12, 1:04 PM
Mike Auger, CMI's Avatar
Mike Auger, CMI Mike Auger, CMI is offline
Default Re: Little Giant Pro series Ladder
I have the little gialnt mine is the XE series so its only 22 feet (maybe 19?) in any case that thing is awesome. Very sturdy feeling when extende or as a step. get the leg leveler attachement comes in handy.
Mike Auger, CMI
Certified Master Inspector
RI Reg. # 32856
RI Radon Lic. # RMC-142
(401) 578-4878
A U.S.A.F. Veteran Owned Corporation
Old 7/23/12, 1:16 PM
Troy N. Pappas's Avatar
Troy N. Pappas Troy N. Pappas is offline
I have 12 ft Xtend and Climb, 22ft Little Giant, and 28ft Werner Fiberglass extension.
The 22ft Little Giant gets me on 90% of the roofs. It is a great ladder.
Troy Pappas Virginia Beach Home Inspector
Professional home inspector serving Virginia Beach, Norfolk, Suffolk, Portsmouth, and Chesapeake 757-418-0944
Old 7/23/12, 1:44 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
I carry the 15.5 ft Xtend N Climb, and bothe the 15 ft and 23 ft LG's. The LG's are great ladders, but rarely come out of the truck.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/23/12, 3:32 PM
Juan C. Jimenez Juan C. Jimenez is offline
I have the little giant 22' and I just bought a 28' extension ladder. The 28' foot is so much easier to use. You can not extend the LG's while its standing up. So if you need it fully extended to get on a roof, then you need a lot of clearance. I wish I would I have bought a smaller cheaper LG and an extension ladder from the beginning. I carry around my 28 foot on a mini van and the LG inside. You should have no problem carrying around the extension ladder on the HHR cargo. Just install a ladder rack on it.
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Chesterfield Home Inspector
Petersburg Home Inspector
Richmond Radon Testing
Old 7/23/12, 3:57 PM
jashley's Avatar
Adrian steel is the ladder rack I use currently. I also have a 28 ft. Not sure why I put the 24ft on here. I had a 24ft before and traded up to the 32ft but found it was a little heavy and too much for what I was doing. So I went to a 28ft and it feels about right. I just picked up a 26 LG pro series for $389 with a leveling stand - no taxes and Free Shipping. I considered the Werner but I'm silly and liked the black LG Pro look a little better. Booked 3 inspections today screwing around on the computer. LOL
Old 7/23/12, 4:09 PM
Christopher Currins's Avatar
Originally Posted by jjimenez View Post
I have the little giant 22' and You can not extend the LG's while its standing up.
Why not. I have a 22' Werner, same style as LG, only difference is it's lighter.
No problem fully extending it when in vertical position.
CBC HOME INSPECTIONS
Christopher Currins
Professional Home Inspector In Edwardsville, Glen Carbon, Godfrey, Maryville,
Fairview Heights, O'Fallon and surrounding areas of S
outhern Illinois
We Make It Safer
Old 7/23/12, 4:18 PM
I have done it in tight squeezes but I had to do it one leg at time. I raise it one leg, put one lock it, reset my arm, remove the lock and raise it another leg. It's a pain. With my new extension, I just stand it up and pull the rope. Looks like Justin already bought the LG. He looks like he can handle it better than I could though.
Is there an easier to way to do it because I was fully extending it first and then walking it up. Easy, but not great in tight spots.
Juan Jimenez
God. Family. Home.
804-269-4321
Old 7/23/12, 4:30 PM
What I do is unfold it, start at the bottom rung (step) and extend that section fully, flip it around, do the same with other section.
Can be tough in tight spots, but generally no problem at exterior.
Christopher Currins
outhern Illinois
We Make It Safer
Old 7/23/12, 5:01 PM
does the xtend & climb get you on to a roof ok? I would think around here anyway it may be just short, but i rarely measure the roof edge. Seems like an easier ladder to tote around though.
Mike Auger, CMI
RI Reg. # 32856
(401) 578-4878
Old 7/23/12, 5:32 PM
In most cases, yes. I walk almost every roof, and like I sad, the LG's rarely come out of the truck. Usually, second story roof-access can be obtained without a ladder from the first story roof, or with the Xtend N Climb from a deck or balcony. If not, I pull out the LG.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/23/12, 5:38 PM
Steven C. Waskewicz, CMI's Avatar
Steven C. Waskewicz, CMI Steven C. Waskewicz, CMI is offline
I have 2 ladders that I've been using for the last 5 years, and they've served me very well.
Similar to what other guys are using,
I carry a smaller Extend N' Climb into the house with me, for getting into tight attic access locations, and I think it goes up to about 12'.
It's especially useful in closets, where the hatch or scuttle is straight above the clothes in the closet...
and
I also have a 22' Little Giant Fiberglass ladder that I keep in the bed of the truck, for accessing roofs.
Its a very safe ladder in both the "A" frame standup method, as well as fully extended.
Steven Waskewicz
Rest Assured Inspection Services, LLC.
719-510-7703 mobile all the time
Ask me about The Home Energy Score
Old 7/23/12, 6:59 PM
bchesser's Avatar
bchesser bchesser is offline
I carry the 15.5 ft Xtend N Climb, M26 LG, and a Werner 32 ft. I use the Xtend on most inspections. The LG is a great ladder it is hard to use in the extended role, but is too versatile not to have. The Werner is just good to have for the high roofs.
Brian Chesser
770-363-5672
www.inspectorofhomes.com
Retired Veteran Run
Old 7/24/12, 6:01 PM
InterNACHI Applicant
That's about 10lbs heavier than the 22ft. I doubt that you could tilt it fully extended without having someone hold the bottom in place. Raising / lowering the last section vertically always leaves me worried about breaking fingers or thumbs.
This guy struggles a bit with the 26 footer (listen to him huffing and puffing by the time he is done). http://www.youtube.com/watch?v=9mj0KwzO-Ew
I love my 22ft, but the reality is it usually stays in the truck (I do use it a home a lot), while I use my Telesteps and 32ft extension in the field. I do use the LG on inspections occasionally, but it's usually too big and heavy for the small roofs and too short for the tall ones.
Chuck Evans (TREC #7657)
Houston, TX
Old 7/25/12, 11:51 AM
Ted Hartman Ted Hartman is offline
Please Note: Ted Hartman is a non-member guest and is in no way affiliated with InterNACHI or its members.
You should check out Little Giant's new fiberglass articulating ladder: Little Giant Conquest.
http://littlegiantladders.com/multi-.../conquest.html
It's designed specifically for home inspectors and insurance adjusters. Already adopted by State Farm and Allstate for mobile adjusters. Just a heads up though, you don't want to buy them from this web site, contact Little Giant and tell them where you buy your ladders; e.g., Grainger, Fastenal, etc. They can sometimes arrange free field trials, depending on the size of your fleet.
You'll get a much better price.
P.S. In the interest of full disclosure, I am an employee of Little Giant Ladder Systems.
Little Giant Ladder Systems jleahy Miscellaneous Discussion for Inspectors 14 8/19/09 1:01 PM
Ladder Safety Extensions mcyr Miscellaneous Discussion for Inspectors 3 4/6/09 11:10 AM
Little Giant 1A 22 foot ladder for Sale dmoriconi General Inspection Discussion 0 10/19/08 11:08 AM
Ladder Safety from ITA badair General Inspection Discussion 4 8/9/06 7:59 PM
Ladder safety by Rick Bunzel gbeaumont Miscellaneous Discussion for Inspectors 9 3/24/06 6:24 PM
