John Malo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi,
I am trying to get some information on how long it would take an inspector to fully inspect a single family home that is built in the 1920. The home is about 1400 SF, 3 BR, 2 Baths, gas furnace/water heater, two stories with full basement and 1 car garage. Thanks, JM |
dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
2 1/2 to 4 hours depending on many factors. If he did it in less than 1 1/2 hours, he would have performed the minimal requirement for doing home inspection (sampling of windows, outlets, viewed roof from ground, inspected attic from access hole only).
Why do you ask? |
Long time ago I used to think about how long an inspection took. Now I never even consider that important. AS someone said, "I can do it fast or I can do it right. Which do you prefer?" Ive done some very old, small houses that took most of the day due to the large number of issues. Took almost as long to write the report to my satisfaction. Without too many problems or issues figure on 2-4 hours. With problems and a small crawl space add an hour or so. I generally just say it takes as long as it takes.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Each house is unique and the time to inspect it properly will vary with its general condition, age, and any upgrades/additions that have been added to it.
Bank on at least 2 hours minimum with a possiblity for a lot more. I wouldn't book another inspection for that day just in case the inspection might take more time. |
Homes older than 1950 or so take me longer, I would guess a minimum of three hours for me to do it. Maybe longer.
Usually takes me 3 1/2 - 4 hours, and thats with my wife helping me. That includes going over report with client on site and a ready to take home binder report for the client. If I'm by myself, which doesn't happen very often...5 hours.
Darrell Hadler CMI Five Star Home Inspections Medicine Hat, AB. Canada NACHI# 04111082 Cell phone# (403)502-3593 Inspected once . . . inspected right! (website) http://inspectorpages.com/dhadler
I would typically take 3-4 hours for the house you described. Could be a bit longer if we found more than its share of problems.
p.s. John, did you ever live in Windsor Ontario by any chance? |
Ashli Norton is a non-member guest and is in no way affiliated with InterNACHI or its members.
Even though I just got in the PROFESSIONAL(certified) inspections (was doing REO's and BPO's @ first) i would say that it depends on the size of the home and of course the issues, you could have a perfect home that ia breeze to inspect and another thats just well you know...but for the simple answer no shorter 2 1/2hrs
On that size home, 2 ½ to 3 ½ hours is pretty typical for me. But it all depends on whether or not the house (in question) has been maintained or not over the years. I've had a few homes (under 2,000 sq. ft.) where it took me close to four hours to complete due to many defective items throughout the home.
Most people take care of their homes, but there are some people (for some strange reason) that do enjoy living in squalor. |
30 Mins Tops, thats about how long it would take to walk around look at a few things and type in the report D12 required for replacement.
On a serious side, I would book it for either the morning or the after noon appoint ment, so half the day would be afforded to the inspection and report is completed at home if needed or done on site if no real bad issue's arise. ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 813 2353 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
I recently did a 58 year old home that had gone through many owners over the years with additions and "upgrades" over the course of time. These kinds of houses can be very challenging as they often will "tell a story" and if you take your time you can unravel much of that story. This is important for a couple of reasons; you need to be able to convey to your customer what has transpired and piece together how past "improvements" may very well be the cause of some of the existing and persistant problems typically found on older homes. What some past owner did almost always has an impact and in this particular case exacerbated a serious problem of water intrusion. Each an every attempt they tried to correct or "live with" the problem caused more serious issues to "accumulate". With older homes I set aside the entire day because I never know what I will find and by the end of the inspection your brain can go on overload with the amount of information you will now have to put into a report that makes sense, protects your customer and finally limits your liability while still putting everything into perspective. What you may think is a minor issue may be monumental to the buyer and vice verse. It is a fine line to walk at times. Main thing I can say is take your time, do it right even if it means telling the client it may take some additional time to put together the report. Ive never had one yet get upset because I wanted to be thorough.
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Typically for me it would take 3 hours and 13 minutes and 12 seconds.
But seriously, it would take 3 hours and 13 minutes! Many things need to be factored in...But I tell customers on average a home should take 3 hours. |
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Thank you all for the inputs. I asked the question because I am setting an appointment with the inspector to inspect a home. I just want set enough time aside so the inspector can do complete job.
| Scumbag NAHI hits new low at ASTM meeting yesterd | cmccann | General Inspection Discussion | 27 | 2/22/07 3:31 PM |
| Buyers Best Home Inspections | ddinwoodie | Miscellaneous Discussion for Inspectors | 6 | 9/4/06 7:20 PM |
| Misinformed CAHPI member? | rwand1 | Canadian Inspectors | 4 | 8/1/06 9:39 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
| No Ashi / Nachi Conflict!! | fcarrio | Legislation, Licensing & Legal Issues for Inspectors | 5 | 2/11/06 1:32 PM |
