Old 3/23/06, 9:29 PM
John J. Passailaigue, Jr.'s Avatar
John J. Passailaigue, Jr. John J. Passailaigue, Jr. is offline
Send a message via AIM to jpassailaigue
Default Main Electrical Shut-off?
Members,
I did an inspection today of a new home for a very nice lady. She is very knowledgable about a great many things. I noted that the main electrical panel outside the home had no main electrical circuit breaker. I made a note of it on her report saying that there was no main electrical shut-off for the main panel, but there was one for the auxillary panel. 200 amps worth. Unfortunately, if you flipped that one off, the main panel is still live. Isn't there a code stating that there has to be a main electrical shut-off? I looked through my code book and every other book I could find but nothing that comes out and says there has to be one. Help?
John
Old 3/23/06, 9:37 PM
gbeaumont's Avatar
Default Re: Main Electrical Shut-off?
John,
what is in the exterior panel, and what does it feed?
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 3/23/06, 10:27 PM
Richard L. Bennett Richard L. Bennett is offline
John
As I understand your question you must have a master cut off or six or less breakers regardless what they feed
I believe that a master breaker can be external with in sight but this should be substantiated by someone that can site code
rlb
Old 3/24/06, 8:21 AM
David P. Valley's Avatar
Originally Posted by jpassailaigue
I noted that the main electrical panel outside the home had no main electrical circuit breaker. I made a note of it on her report saying that there was no main electrical shut-off for the main panel, but there was one for the auxiliary panel. 200 amps worth. Unfortunately, if you flipped that one off, the main panel is still live. Isn't there a code stating that there has to be a main electrical shut-off? I looked through my code book and every other book I could find but nothing that comes out and says there has to be one. Help?
John
#1, you should never attempt to shut down an electrical system.
#2, if you did (as you say) shut down the 200 amp auxilary panel and the power remains on, and there's no other main breaker for shutting down the entire home....You have a safety issue.
Old 3/24/06, 11:18 AM
Jeffrey R. Pope's Avatar
I spoke with John last night. As it turns out, there were only five breakers in the service panel.
No need for a "main" disconnect.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/24/06, 11:27 AM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Jeff,
Did he call you?
Asked another way (and with no inference of a lack of knowledge on John's part)
If I ask a question here and don't get a timely response, can I call you? (is there a 'sheepish' smile on here somewhere!)
Seriously, I view you as a hell of a resource (I spoke with several in Orlando who feel the same)
Humbly,
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 3/24/06, 11:35 AM
Originally Posted by mgault
Jeff,
Did he call you?
Yes, he did.
Certainly. I'm happy to help if I can.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/24/06, 11:59 AM
Jeff,
You're now in my phone as Jeff Pope-Ca (to remind me not to call you at 0900 my time
Thanks!
- Mike
NACHI05040682
(843) 442-9755
Old 3/24/06, 12:12 PM
Jeff
Help me out a little --- if a main disconect is required (over six throws) how accessable does it have to be?
I have seen a simular question in reff to condos but what about a normal home?
rlb
Old 3/24/06, 12:39 PM
For SFH, the term would be "readily accessible," meaning - accessible to the occupants for service and/or emergency operation. This would also include all applicable clearance requirements.
230.70(A)(1) Readily Accessible Location. The service disconnecting means shall be installed at a readily accessible location either outside of a building or structure or inside nearest the point of entrance of the service conductors.
230.72(C) Access to Occupants. In a multiple-occupancy building, each occupant shall have access to the occupant’s service disconnecting means.
Exception: In a multiple-occupancy building where electric service and electrical maintenance are provided by the building management and where these are under continuous building management supervision, the service disconnecting means supplying more than one occupancy shall be permitted to be accessible to authorized management personnel only.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/24/06, 2:19 PM
Thanks Jeff
I know this has been explained before but for some reason it just did not stick
Sort of open for some common sense depending on how the house is built
When we spot some of these things and flag them I guess we should remember that there is some gray areas
Thanks again
and have a good day
rlb
Download the videos here all about physics and electricity jtedesco1 Electrical Inspections 5 9/14/08 3:58 PM
Handbook for Electrical Safety pabernathy Electrical Inspections 1 1/1/07 1:14 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 1:48 AM
