Hvac contractor surmised that it was the result of A/C at 60 degrees or below icing. That the ductwork was causiong the condensation to we t the insulation. It was stil saturated after 2 and a half months. Any thougths?
Hi Jack,
uninsullated ductwork is a major problem on pre 1994? Manufactured homes, once the ductwork has started sweating both the insullation and the fllor are likely to be toast, I wouls recommend removing the moisture barrier (if fitted) and replacing the insullation, this will also give you the opportunity to properly evaluate the subflooring which I suspect will also be in very poor shape. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
It could also be from many leaks in polybutylene plumbing pipes. I certainly wouldn't rule it out.
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
| Inspector Wendy's Home Inspections-Service Areas | wforsyth | Miscellaneous Discussion for Inspectors | 57 | 9/5/06 11:10 PM |
