Old 7/20/08, 7:55 AM
sfalvey sfalvey is offline
Default Manufactured-strapping and piers
I don't do many manufactured houses and did look through the archives but I still have a couple of questions.
Unit is 1998, relocated to this site 1 year ago and never lived in, well pump was turned off when I got there, Agent turned it on for inspection.
1. Does the strapping have to be tight (or is some slack acceptable) and does the strapping get connected to the frame or is it OK if it is connected to the exterior/perimeter framing under the siding?
2. The unit is set on a concrete slab that is not even (level is a different story) I noticed one of the CMU's as the bottom support had a crack because of a small ridge in the concrete. Due to the crack, the pier is now "flat" to the concrete and should not crack/break any further. Should this be a concern or just note it and move on?
3. Non pressure treated framing material is used in several areas to "block" the frame, is this a problem.
4. The manuf. black covering of the joists had moisture/condensation on the underside, there is no venting in the skirting but we have had very high humidity the past few days. Just recommend vent skirting?
5. The center connection point was nicely spray foam sealed, but had a tag sticking down that said "support pier required at this location" (none was present) , does anybody know if this would also indicate the necessity for additional ones the length of the unit.
6. The skirting doesn't set on the slab all the way around but sets on PT framing in areas where the slab "fell short".
Not asking for you to write the report, but opinions are appreciated.
manufactured-strapping-and-piers-img_3847.jpg   manufactured-strapping-and-piers-img_3848.jpg
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 7/20/08, 9:49 AM
Ron Carter Ron Carter is offline
Default Re: Manufactured-strapping and piers
Hi Scott first the strapping does not have to be tight is what I have been told, second the skirting does have to be vented, Not all the ones I do have pressure treated on the piers. As far as moisture how damp was the ground was there excessive moisture present, if so was this due to no venting.Ron
Old 7/20/08, 12:12 PM
Banned
If the ground was damp or wet, better drainage and a moisture barrier should be the first line of corrective action.
Old 7/20/08, 9:26 PM
Hi Ron,
The pad is a poured slab and I didn't see any leaks so I am assuming the moisture is due to the humidity and that would be minimized with venting.
With the strapping, does it have to be to the frame, they were also spaced about 10' apart.
Thanks,
Scott Falvey
Newbury, NH
NACHI#05051292
Old 7/21/08, 1:15 AM
gbeaumont's Avatar
Hi to all
Should be fairly tight (thats why they have ratchet straps)
I would call it out as broken and in need of repair
Possibly not but would depend on thickness
Yes strongly
Yes, piers should be at every location required by the manufacturer
Maybe OK could use a picture
Overall a crap re-siting of a manufactured home and doesn't meet the manufacturers installation instructions, I'll bet the home replaced an older model on the same slab.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 7/21/08, 6:42 PM
Originally Posted by gbeaumont
Hi to all
Regards
Gerry
Actually Gerry, it was relocated to this site, but none the less it is a less than professional job. The sitework wasn't much better. I bet the guy didn't spend more than an hour there with his excavator.
Here is a photo of the skirting off the slab and on the PT framing.
manufactured-strapping-and-piers-img_3852.jpg   manufactured-strapping-and-piers-img_3840.jpg
Scott Falvey
Newbury, NH
NACHI#05051292
Inspection of Manufactured Homes jmondragon General Inspection Discussion 44 12/22/07 11:15 AM
Water heater strapping in manufactured homes ilpowell Plumbing Inspections 10 2/24/06 5:20 PM
