Jim Prindle is a non-member guest and is in no way affiliated with InterNACHI or its members.
Home is missing ridge blocks from entire ridge/run.
Home was built 1992. Truss construction. Any situation where this is permissable? No code books I have reference back to 1992 Thanks Last edited by Jim Prindle; 3/2/08 at 7:35 PM.. Reason: wrong picture |
cyezza is a non-member guest and is in no way affiliated with InterNACHI or its members.
For what appear to be relatively small trusses, installation 24" oc with sheathing on top and some lacing about 10' oc perpendicular to the bottom cord should suffice. No framing along the ridge is needed, typically. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Posted new pic... sorry bout that.
Jim, if you are referring to blocking at the peak for plywood support, you do not need any.
There is lack of a ridge vent that I can see though which was common for that age. Hope this helps. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Hi Jim, what is happening to the left of the picture? Is that the start of a hip roof?
Dick Dick Moran True Blue Home Inspections A Div of RAM2, LLC. Clarksville, MD 240-832-6838 MD Home Inspector License 29927 |
Yes, a hip. Haven't seen any houses of this type without ridge blocks.
What was more curious is I inspected the house down the street of the same age sometime back that had 'em. Thanks for help. |
imho:
The blocks, guessing what you mean, are put in place when the trusses are lifted. They are there to hold proper spacing till the sheathing is on. They are typically made from scrap lumber, and don't seem to be structural. tom |
Thanks for the responses. In my neck of the woods, they are required now in 2x material or better for perimeter nailing.
| Missing Ridge Board | pdickerson | Structural Inspections | 19 | 9/21/07 9:33 AM |
| Ridge Vents | kmcmahon | Exterior Inspections | 18 | 7/19/07 2:27 AM |
| Ridge Vent | tneumann | Exterior Inspections | 11 | 3/17/07 11:25 PM |
| Rafter to Ridge connection | rskinner | Structural Inspections | 17 | 8/26/06 8:33 AM |
| Rafters separating from ridge board | jmichalski | Structural Inspections | 8 | 3/13/06 8:52 PM |
