Old 11/18/09, 5:52 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
Default Moisture Intrusion: Please proof this new inspection article.
http://www.nachi.org/moisture-intrusion.htm
Find a Home Inspector
Find an InterNACHI certified Texas Home Inspector (and anywhere else in North America)
Old 11/18/09, 7:09 PM
Default Re: Moisture Intrusion: Please proof this new inspection article.
A few points for design;
Statergies;
Keeping water and precipitation out
Managing plumbing leaks
Avoiding condensation inside the building and its envelope
Controlling entry of humid outside air
Controlling indoor sources of humidity
Designing assemblies to dry out
Providing mechanical ventilation and dehumidification
Air barriers play an important role in moisture control. “We didn’t have moisture control problems until we insulated our buildings and then, to make matters worse, began using materials that were subject to moisture damage, corrosion, mold, and mildew, such as OSB, steel studs and gypsum sheathing.
Old 11/18/09, 9:28 PM
William J. Decker's Avatar
See here. Free to use whatever you want.
http://deckerhomeservices.com/2009-082%20Decker.pdf
http://activerain.com/blogsview/1149...chicago-condos
http://activerain.com/blogsview/7917...nd-more-common-
http://activerain.com/blogsview/9386...tractors-cause
http://deckerhomeservices.com/Sample...0Intrusion.pdf
I also sent Kenton a Power Point.
Teaching a State Licensed CE course on the subject, tomorrow night, at our Chaper meeting.
Seems a former ASHI chapter Pres. is attending, as well.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 11/20/09, 3:26 PM
Rob London Rob London is offline
thanks guys
Researcher and Technical Writer, InterNACHI
Please proof this new article on moisture meters. gromicko IAC2 Indoor Air Forum 1 5/19/09 1:52 PM
Moisture Management mcyr Exterior Inspections 15 9/8/08 1:11 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
