Old 5/23/09, 8:56 PM
John Harrison's Avatar
John Harrison John Harrison is offline
Default moisture meter
Im looking at moisture meters and notice that there are some that do not start to detect moisture under 6%. Is there any required moisture percentage that needs to be identified?
The meters that I have found range
I have recently used a meter much like this one:
Analog Moisture Meter, Wood Moisture Content 10 To 28 Percent, Wood Moisture Content Accuracy Plus Or Minus 5 Percent, Cable Length 36 Inches.
When pressing the probes to you fingers moisture is indicated, and I applied a light mist to a wall and the meter detected moisture.
Moisture Management mcyr Exterior Inspections 15 9/8/08 1:11 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
