Old 12/16/08, 10:48 AM
sbrescher sbrescher is offline
Default mold issue
I did a pre listing inspection back in end of september. The homeowners had a offer and the buyer had a inspection company do the inspection. They noted that there was mold in the crawlspace and the deal might fall through. The realtor called me to let me know that the homeowner might call me and I was wondering if anyone had any ideas on how to handle when they tell me how come I did not see the mold which I did not see when I crawled the entire crawlspace, How long would it take for mold to start?
Old 12/16/08, 10:54 AM
Wayne B. Wilson's Avatar
Default Re: mold issue
Depends on weather or condtions, Things can change in the time sense you did the inspection , dryer vent disconnected pipe leaking new mulch around vents and so on. Did you go check if not i would ( not all inspectors can be trusted) Ducking the stones now but it is true. Vents could even been closed. They may have been a small amount that you didnt catch. Besides that you are not a mold nspector
Old 12/16/08, 10:56 AM
I dont have alot of information about the so called mold, I was wondering so if and when they call me I could be prepared.
Old 12/16/08, 10:57 AM
James E. Braun, CMI's Avatar
Only a couple days. Is the crawlspace vented properly? Does it have a proper moisture barrier? If not, did you note it in your inspection report? Has there been any water losses since your inspection?
Old 12/16/08, 10:58 AM
Yes proper vapor barrier, the only thing I noted in the crawlspace was that the insulation was coming loose and was starting to hang in certain areas.
Old 12/16/08, 11:03 AM
Was you hired to do a mold inspection also? If not and there is just a small amount of mold it could be easily missed and you should not be held responsible because it is beyond our SOPs. Believe it or not a proper visual mold inspection takes just as long as a regular home inspection. Some inspectors purposely look for mold for they can collect the testing fees.
Old 12/16/08, 11:05 AM
Was not hired to look for mold, I guess I might be making to much of this it is just that I never had someone complain about an inspection before and I just want to cover my own A**.
Old 12/16/08, 11:08 AM
If the seller does give you a call, schedule a time to look at the crawlspace, take pictures and document it, just in case. Figure out what happened and explain to the seller why you feel you are responsible or not. I am leaning towards the not.
Old 12/16/08, 11:10 AM
thanks, will wait for the call and thank you for the advice.
Old 12/16/08, 11:11 AM
Also after it is all over. Give the documentation to the Realtor for he/she knows you got it handled and you can be counted on to do so in the future.
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Scott,
If the conditions are right, Mold can grow within 24-48 hours.
Your inspection was a picture in time! What if the water heater failed within 3 months? Would you be held accountable or worse negligent? I think not.
Did you document the insulation issue or the crawl space?
BTW Was the crawl space vented?
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 12/16/08, 11:27 AM
I noted that the insulation was hanging, vapor barrier was loose in one area and that the dryer vent terminated in the crawlspace.
Old 12/16/08, 11:54 AM
Just the vapor barrier being loose and/or the dryer vent terminating in crawlspace can cause mold in those areas.
Old 12/16/08, 12:22 PM
Dennis R. Goudreau Dennis R. Goudreau is offline
ditto,food source, moisture, humidity
Old 12/16/08, 6:48 PM
Read YOUR forms and reports. Make sure everything about mold/environmental is in place, and documented/nariated properly. I am with James. Take another look. Have you read "Inspect and Protect" by Dr. Swift? A must read. Remember, it only takes 24 to 48 hours for mold to form. I have seen pictures in New Orleans from Hurricane Katrina. Homes got consumed with inches of mold in walls and ceilings in just days after the hurricane hit. It does not take long.
Interesting article about mold by litigation. gromicko IAC2 Indoor Air Forum 16 5/5/11 7:48 PM
Mold mcyr IAC2 Indoor Air Forum 5 9/13/10 10:31 AM
GAO calls for collaboration on indoor mold guidance. gromicko Legislation, Licensing & Legal Issues for Inspectors 32 11/11/08 8:47 AM
The new scoop on mold insurance Brian A. MacNeish Ancillary Inspection Services & Additional Topics 2 1/1/08 1:30 PM
CMI imposter? jbraun Certified Master Inspector (CMI) Discussion 118 11/26/07 4:55 PM
