FrameGuard® Mold-Resistant Wood Product Description FrameGuard® mold-resistant wood is coated wood combining a blend of anti-mold chemicals with borate technology, alleviating problems from mold, termites and decay-causing fungi. It can reduce complaints and costly liability claims. Applications Intended for interior use, FrameGuard wood is available in framing and truss lumber, plywood, OSB, and SIPs, as well as other engineered wood products. Performance Capabilities FrameGuard wood is coated with a water-based combination of EPA-registered active components that provide a broad spectrum of protection. The coating is applied at a treating plant or other facility where quality of coverage can be controlled more precisely than on a job site. An independent research study of various mold preventatives provides an unbiased evaluation of alternatives. This study is available from Arch Wood Protection. Features In addition to its mold- and pest-resistant qualities and competitive warranty, FrameGuard wood is easily identifiable due to a green colorant that is mixed with the active ingredients. Offering a host of environmental benefits, FrameGuard wood:
Warranty FrameGuard® wood is backed by a competitive limited warranty. Contact us for details. Model Specification See elsewhere on this site or go to www.frameguardwood.com for an editable model specification. Company Information FrameGuard® mold-resistant wood was developed by Arch Wood Protection, licensors of the popular Wolmanized® brand of preservative treated wood and Dricon® fire retardant treated wood. For More Information Download the accompanying product guide. Contact Information To locate a source, call 866-736-7366. Arch Wood Protection, Inc. 1955 Lake Park Drive, Suite 100 Smyrna, GA 30080 Tel: (770) 801-6600 Fax: (770) 801-1990 E-mail: info@wolmanizedwood.com Web site: http://www.wolmanizedwood.com Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I like the color ....actually saw a bunk of 3/4 tg at a home center last week....first time I've seen it Marcel....
Interesting.
Thanks Marcel! Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
That has got to be a lot better then the stuff they come in and spray on after it is framed.
There was a (builder) here in town bragging about using the spray on and I thought it was very FAUX application. Missing a lot of surface area and only doing the inside. I wonder if it will keep the wood from swelling when it gets wet? "I create controversy whether they like it or not" |
Hi Marcel, Here is a siding job I just completed. I happen to like the product as it gives you a smooth surface under the siding and you don't need building paper. Not sure of the cost though.
I'm doing another siding job with insulated siding. It's a foamed backed siding that has an R-5. That along with triple pane windows and proper ventilation my client will save plenty on their heating cost. Hope your staying warm. -26 at my house this AM. Pete |
Peter,
I do not think that is the same product that Marcel posted. You posted a picture of the OSB that hase the skin on it. "I create controversy whether they like it or not" |
Here's a little quiz for everyone. Can you pick out the mistake that was made on this building. It won me the job and I corrected it when we sided the building.
Have fun!!! |
Same idea though, isn't it? |
No! What got done with all the flashings and heads of the windows? What got done at the sills of the windows to kick the water out over the siding? "I create controversy whether they like it or not" |
Hi. Peter;
The Zip System, for wall and roof sheathing, just started seeing it up here. I am with Carl, how was all the flashing treated at windows and ledger for the future Decks? -20 here this morning and up to -13 right now. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
And the roof lines.
And lets not forget the flashing on the cap of the fireplace. "I create controversy whether they like it or not" |
Then we installed undersill trim under the window inside the built in J to keep the siding tight to the wall. Marcel. All the ledgers where flashed with copper, I even use copper nails when installing any siding accessories over the flashing. |
For the Roof;
http://www.goyoders.com/docs/osb/zip...stallation.pdf What is ZIP System ® Wall Sheathing? Zip System wall sheathing has a built-in, water resistive barrier that lets you say goodbye to housewrap forever. Simply install the panels, tape the seams, and you have a complete structural wall system and a water-resisitive barrier all-in-one. ZIP System wall combines the strength and stability of a high-performing panel with the enhanced weatherability provided by the product's water-resistive barrier. ZIP System wall panels are backed by our 30-year limited warranty. Eliminates housewrap
http://www.huberwood.com/media/2009/...GLISH-1-08.pdf Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The chimney cap was installed later by the fireplace contractor. Your getting close though! |
Post a picture that is bigger. Was there a cricket behind the fireplace? And the little shoulders on the fireplace where it meets the roof looks out of wack. "I create controversy whether they like it or not" |
| Interesting article about mold by litigation. | gromicko | IAC2 Indoor Air Forum | 16 | 5/5/11 7:48 PM |
| Can someone explain why wood in contact with concrete causes rot? | gromicko | Miscellaneous Discussion for Inspectors | 46 | 1/16/11 11:15 PM |
| The Rise and Fall of CCA Wood Preservatives | mcyr | General Inspection Discussion | 3 | 5/4/08 11:19 AM |
| The new scoop on mold insurance | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 2 | 1/1/08 1:30 PM |
| CMI imposter? | jbraun | Certified Master Inspector (CMI) Discussion | 118 | 11/26/07 4:55 PM |
