Old 1/5/06, 11:34 AM
James M. Troth's Avatar
James M. Troth James M. Troth is offline
Default Multi color pen
Here is a tip. If you are using paper as your way of taking notes while inspecting consider using various color ink pens as a way to help distinguish notes from each other.
Example Upstairs Bath note it in Blue and use green for the downstairs bath.
Habitation Investigation LLC
http://www.homeinspectionsinohio.com
Old 1/5/06, 6:11 PM
cmccann's Avatar
cmccann cmccann is offline
Please Note: cmccann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Multi color pen
Cool tip!
Old 1/5/06, 6:33 PM
Doug Edwards,  CMI's Avatar
I often will use a red pen to highlight a real problem area. It is a real good tip. Thanks
Old 1/5/06, 8:19 PM
Michael R. Boyett's Avatar
I use multi-colors as well, especially when doing duplexes and 4-plexes. Helps a lot to keep things separated.
