Old 3/16/10, 6:00 PM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default My electrical fire
My wife was drying her hair (1875 watt hair dryer) as I was talking to her. We both smelled that familiar smell and before she could turn off the dryer, flames shot out from the switch. She wasn't hurt, she tried to turn it off but it wouldn't turn off, we pulled the cord out of the GFCI outlet. The dryer also had an inline GFCI plug. There was no smoke, fire, or sparks at the outlet and no damage to the outlet.
Shouldn't the GFCI outlet or the inline GFCI plug have tripped and shut the power off?
I checked the outlet and it trips with my tester and with the test button.
my-electrical-fire-p3160165.jpg   my-electrical-fire-p3160166.jpg   my-electrical-fire-p3160167.jpg   my-electrical-fire-p3160168.jpg   my-electrical-fire-p3160174.jpg
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/16/10, 6:14 PM
Chuck Evans's Avatar
Default Re: My electrical fire
I'll take a crack at it:
GFCI monitors for leakage of current. The device can burn up, but if there is no significant disparity (5+ mA) in the amperage being sent through the ungrounded (hot) conductor and what comes back through the grounded (neutral) conductor at the GFCI device it wont trip the GFCI.
If total amperage doesn't exceed the rating of the breaker, it won't trip either.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 3/16/10, 6:25 PM
That is how it works, but I would think that the burning would cause a change in the amperage sufficient enough to trip the GFCI.
Michael Merino
Old 3/16/10, 6:31 PM
Jeffrey R. Jonas's Avatar
Maybe an AFCI would have tripped.
Old 3/16/10, 6:40 PM
AAH! you are probably correct!! But, shouldn't the GFCI have tripped? I looked at the GFCI and it appears OK and operating correctly.
Michael Merino
Old 3/16/10, 6:50 PM
Have you checked for recalls yet?
Assuming the air intake screen is not clogged with hair, like most are (and women never seem to clean) and you don't find a recall, report the incident anyway to the CPSC. Also, call Sunbeam and report the incident.
Seems like a lot of work for a $20 hairdryer, doesn't it... but if it adds to a growing list of incidents, it may be the one needed to trigger a recall!
Do the right thing, man!!! Save the world from shoddy products!!! Your wife could have been seriously injured (aka... hair catch fire)!!! Think of the "brownie points" and "special favors" you'll earn when she finds out you're taking on the fight!!!
Old 3/16/10, 7:00 PM
Bruce A. King's Avatar
That is unfortunate but normal, the fire was heat dissapation which is wattage, the wattage is driven by the current, if the neutral did not have current you would not have the wattage. The hair dryer would have shut off when the heat from the fire reached the little heat sensor in the air output section or when a wire burned in two. Never leave hair dryers etc plugged in when not using, it can fail in other ways too.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
LOL, she will just laugh at me, like usual
Michael Merino
Old 3/16/10, 7:21 PM
Bob Elliott's Avatar
Just caught this.
I vote for AFCI would have tripped it.
The voltage may have stayed the same while it arced.
1850 amps (damn ,she must have long hair to need that sorta power).
Old 3/16/10, 7:41 PM
mnahrgang's Avatar
Can you imagine what might have happened, if she would have set it down, and then sprayed on the hair spray just as it ignited? She'd have been doing a Michael Jackson Pepsi commercial. It's awesome that no one was hurt.
Mark Nahrgang
www.HeyMark.info
Old 3/16/10, 7:42 PM
Originally Posted by belliott View Post
Just caught this.
Watts Bob... not Amps!
Old 3/16/10, 8:04 PM
Watt you talking about ?
The amps on that thing are pretty close to tripping a 20 amp breaker all on it's own by the way.
Thanks as always for your loving correction.
Be sure to spell check me.(thanks)
Old 3/16/10, 11:42 PM
WATT-ever !!!
Old 3/17/10, 12:54 AM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Glad she's OK.
Heres some hair dryer info.
http://home.howstuffworks.com/hair-dryer4.htm
Even with this screen in place, you'll need to periodically pick lint off the screen. Too much lint can block the airflow into the dryer, and the hair dryer will overheat with less air carrying away the heat generated by the nichrome coil or other type of heating element. Newer hair dryers have incorporated some technology from the clothes dryer: a removable lint screen that's easier to clean.
http://www.dallasnews.com/sharedcont...s.c810bf8.html
Millions of Americans start their day by blow drying their hair. However, a News 8 investigation discovered hair dryer complaints that included shooting fire, electric shocks and even statements of hair dryers "turning on" by themselves.
Old 3/17/10, 8:39 AM
Marcel Gratton's Avatar
Michael,
I've seen GFI's that looked like that hairdryer; of course they weren't offering the protection any more...
On The Level Inspection
Gatineau, Québec
Coming to Schaumburg, Ill - Electrical Training with The Electrical Guru ksitzes Inspection Education & Training 12 3/17/10 4:19 PM
Download the videos here all about physics and electricity jtedesco1 Electrical Inspections 5 9/14/08 3:58 PM
Electrical Fire Safety jtedesco1 Electrical Inspections 3 2/1/08 9:02 AM
Handbook for Electrical Safety pabernathy Electrical Inspections 1 1/1/07 1:14 PM
