Old 7/26/11, 6:18 AM
Curtis Hildebrand Curtis Hildebrand is offline
Send a message via AIM to childebrand
Default Mysterious Crawlspace
I was inspecting a crawlspace yesterday which was one of the best crawlspaces I've ever been in. It was 3 feet high with insulated walls. The humidity ranged around the 50% mark. There were no moisture stains of any kind. It had a functioning dehumidifier. Strangely enough, though, this crawlspace smelled very musty and this smell permeated through the entire home. The only potential issues I found causing this was no ventilation, damaged stucco throughout the exterior and no sump pump (they had a drain which drained water out of the pit to the town sewer line). Has anyone found a similar crawlspace with no apparent source of odor?
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/26/11, 8:31 AM
James H. Bushart's Avatar
Default Re: Mysterious Crawlspace
Describe the vapor barrier.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 7/26/11, 1:09 PM
The floor was concrete with no vapour barrier. The walls were Logix (permanent styro forms on both sides). Half the walls had interior vapour barrier and half did not. There was no barrier at the floor joists.
Old 7/26/11, 2:36 PM
James E. Braun, CMI's Avatar
Where is the ductwork ran?
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 7/26/11, 2:46 PM
Christopher Currins's Avatar
Did it have a p-trap?
Christopher Currins
Certified, Licensed
Old 7/26/11, 2:49 PM
Jeffrey R. Jonas's Avatar
And what is keeping the trap primed?
Old 7/26/11, 10:33 PM
There was no P-trap. The pipe was just a straight pipe running into the concrete. I couldn't see much of it. There was no sewer smell, just a musty, mold-like odor.
Old 7/27/11, 7:31 AM
James Khan James Khan is offline
Please Note: James Khan is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hmm, seems like a tough one to pinpoint the source of the smell. Interested to see what others think.
James Khan
Inspection Software - Infomation Portal
Old 7/27/11, 7:45 AM
Jeff Zehnder Jeff Zehnder is offline
Please Note: Jeff Zehnder is a non-member guest and is in no way affiliated with InterNACHI or its members.
This sounds suspiciously like a closed and possibly conditioned crawlspace. If the side walls are insulated (even with leaving the band un-insulated) and the slab is insulated it is possible. Normally the band would be insulated and a 3-6 inch strip at the top of the block is left uncovered for termite inspections. There should also be a supply duct and a return cut into the floor somewhere. Your photos do not show enough of the crawlspace to be sure.
I don't understand cbottger Inspecting HVAC Systems 7 5/16/11 1:39 PM
Holmes Inspection dcolangelo Canadian Inspectors 20 3/12/10 4:57 PM
? possible reasons for crawlspace mitigation jeubank General Inspection Discussion 11 2/17/09 3:57 PM
