Dale Collins is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Guys:
This is my first post. While I am NACHI certified, I only do flooring, moisture and mold inspections (see www.flooringinspector.com). Recently I have been seeing more and more of what is called “encapsulated crawlspaces”. While the theory and method usually works, sometimes it doesn’t. And, in fact there are times when the liner is floating on water! Presently I am looking @ a $75k encapsulated crawlspace that is a terrible. My question is; although we have standards to inspect both Closed and Open crawlspaces, we have none to inspect these Encapsulated ones. Can anyone offer any advice that I might be able to use to @ least compare, so that the Consumer can force the Contractor to come back and try to get this thing to work/dry the crawlspace? Sincerely, Dale from central TN |
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Dale i have not seen any problems here as of yet
NACHI:
Please correct that I am not a member! Sincerely, Dale |
NACHI:
Please correct the note that says "I am not a member"! Sincerely, Dale |
Staff can't do it for you. Only you can change your posts to member status. Log out of the message board, then log back in with your InterNACHI member username and password.
BTW: There is an entire members-only half of the message board that you can't see until you log in as a member. Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
I hope you mean't 7.5k, if someone paid 75k....... The issue is likely with improper grading, lack of downspout water control and possibly ground water seeping up. It may also need french drains. The crawlspace system should not have been installed on top of a bad water problem. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Hi Guys:
Yes, I know what the problem is, what I need is standards to grade it by. Does anyone have any suggetsions? Sincerely, Dale |
Hi gys:
I'm just checking if my "non-member" was removed? Yes, it is a $75k apartment "encapsulated" crawlspace. BTW, I don't have a problem finding why it's not working. What I need is standards to inspect it by. Does anyone have any recommendations? If it goes to court, my report should be quoting more than my testing/results. Sincerely, Dale |
Hi Guys:
Maybe I'll get the nack of this board soon. I am logged in as a member for sure now. Yes, this is a $75k for the encapsulation only, about 30,000 sq ft apartment. I understand the moisture issues, that's what I do. What I am asking is for "encaspulation standards", so that we can hold the Contractor to them Sincerely, Dale |
I have looked for the same information awhile back. I cannot find any crawlspace liner manufactures that does not allow the liner to be installed over water. These crawlspace liners are basically pool liners, so I was not surprised that the manufacturer allowed this.
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Hi :
I am located in central TN. I agree that it is pool liner (like) material, but it is only 20mil thick, (far less than a pool liner). I really need to prepare this for court. Not that I have a problem proving the crawlspace was not up to standards for a closed crawlspace, but also I need to quote standards for "encapsulation" even if it is the liner manufacture's. (NACHI) It is strange that I am logged in under my NACHI login, but it still shows I am not a member. Sincerely, Dale |
Log out of the message board (link in top right corner). Close window. Close browser. Go back in and log in with your InterNACHI member username and password. You are currently missing out (you can't see them), on the members-only portions of this message board. Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
If you any get any information that says it is not allowed, please email me at jbraun@mo.nachi.org .
Thanks! Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
| I don't understand | cbottger | Inspecting HVAC Systems | 7 | 5/16/11 1:39 PM |
| Preventing Moisture related Problems | mcyr | Ancillary Inspection Services & Additional Topics | 1 | 12/19/07 8:30 AM |
| Tidbits from the ASHI Message Board | jbushart | Miscellaneous Discussion for Inspectors | 126 | 4/27/07 11:05 AM |
| CBC - Province called on to force home-sellers to disclose property's problems | rwand1 | Canadian Inspectors | 3 | 4/5/06 8:40 PM |
