I dont inspect many new homes. This was a model home that was built in 2004.
In the photos attached I wanted to ask about the following. The exterior vents/outlets had no caulking. The basement stair stringer was only nailed at the top. It had a railing but I thought there should be protective balusters. The furnace had no serviceman shut off and the panel was more than 25 feet. The gas fireplace had no glass doors installed. Isnt this required? Noted a few cracked floor joists. Why the air admittance valve. Is this a vent for the condensate drain. Also isnt a code now to drain into a drip cup. Being the house was 2004 was this required then? Should the column have hardware attached to the main beam or is the weight of the home sufficient? Are these legitamite items to note on the report? Thanks Dave Last edited by dmacy; 5/6/08 at 5:52 PM.. |
Here are a few more photos.
The one is of the missing serviceman switch. Panel is across the basement. The stair stringers. This is the only support. 5 nails on each side. Is this enough support. Dave Last edited by dmacy; 3/3/08 at 2:35 PM.. |
scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
Dave,
My code check book says glass doors are required. Dont forget the damper has to be blocked open also. My question is whether that is really a gas fireplace, the pipe coming in is a gas log lighter only. I think there is a difference. Steve |
IRC R312.2: "Required guard on open sides of stairways, raised floor areas, balconies and porches shall have intermediate rails or ornamental closures which do not allow passage of a sphere 4 inches (102mm) or more in diameter. Exceptions: 1. The triangular openings formed by the riser, tread and bottom rail of a guard at the open side of a stairway are permitted to be of such a size that a sphere 6 inches (152 mm) cannot pass through. 2. Openings for required guards on the sides of stair treads shall not allow a sphere 4 3/8 inches (107 mm) to pass through." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
tbrown1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
David:
Looks to be a gas starter for a woodburning fireplace. I that is the case, don't have to have glass doors, I believe. Height of descending handrails at steps should be between 34"-38", for fall-over protection. Didn't see a natural gas shut-off near hearth. Is there one? |
rbunzel is a non-member guest and is in no way affiliated with InterNACHI or its members.
David,
How long have you been inspecting? Most of the questions you are asking are quite basic and answers can be found in the Code Check books. It has been said that if give a hungry man a fish you will feed him for that moment, if you teach him to fish, he will be able to feed himself in the future. Here is my contribution regarding the vinyl siding trim http://www.vinylsiding.org/install/guide.pdf //Rick |
cradan is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't think anyone'd give you a lengthy argument against fastening the column flange to the I-beam.
The fireplace may or may not be a wood-burning fireplace. Many premanufactured fireplaces are not built for use with solid fuel. The gas fixture is standard here for gas-fired fireplaces. In the upper left corner or right corner (usually) of the metal framing, there should be a manufacturer's plate. That will usually tell you the type of fuel the premanufactured fireplace is approved for.
Because all of San Diego County is rated as a high fire hazard area, my comments above might apply only to premanufactured fireplaces installed in San Diego County. I know we're very tough on wood-burning fireplaces, so tough that some jurisdictions here will not approve the building or installation of wood-burning fireplaces. Last edited by rray; 3/11/06 at 6:04 AM.. |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| Extractd from the archives, Thanks Paul for this list! | jtedesco1 | Electrical Inspections | 4 | 1/2/07 8:51 PM |
