Old 3/5/10, 6:29 PM
James E. Braun, CMI's Avatar
Default Newer roof with wet sheathing
This is a new one on me. A tear-off and replacement of fiberglass shingles was performed on this roof about 6 months ago. About 1/4 of the roof sheathing has mold growth on it and has about 60% moisture content. The roof has just a few pan vents and no soffit vents. The shingle installation looks good. Could the roof actually stay wet all that long since the venting is poor?
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/5/10, 7:58 PM
Rob Jones Rob Jones is offline
Please Note: Rob Jones is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Newer roof with wet sheathing
There could be a number of factors going on. Did they not put down felt? How wet was the OSB when they reinstalled the roof? It would be winter time so that might make a difference. If there is not enough air flow to properly dry out what may have been wet, it very well could "still" be wet.
Are there no gable end vents? If not, I can't imagine that roof/attic is breathing the way it should be. Just imagine how that mold is going to explode once it warms up a bit. Did you happen to get any pics?
Rob
Old 3/5/10, 8:05 PM
jkiser's Avatar
jkiser jkiser is offline
I would say ventilation is a big issue if they are no soffit vents. it would take a while to dry out if there is no air flow.
Old 3/5/10, 8:32 PM
Bob Elliott's Avatar
Did you check exhaust terminations and insulation to.?
Old 3/5/10, 8:37 PM
Jeff Merritt Jeff Merritt is offline
Was it OSB or plywood? no soffit vents= no circulation
Old 3/5/10, 8:52 PM
Brian C. Hoagland Brian C. Hoagland is offline
Everybody is right, inadequate ventilation, improper ducting and incomplete sealing of the penetrations from the living space and the heating ductwork could all easily contribute to condensation on the sheathing especially during the winter.
Old 3/5/10, 8:55 PM
The ceilings by the outer walls have some mold on them too.
The roof was installed in late summer.
Just four pan vents on a 1400 ranch style home with a hip roof. No other venting present.
The humidity inside the occupied home is an unbelieveable 55%.
No ducting in attic.
R-13 insulation in attic.
newer-roof-wet-sheathing-dscf2053.jpg   newer-roof-wet-sheathing-dscf2054.jpg   newer-roof-wet-sheathing-dscf1995.jpg
Old 3/5/10, 9:40 PM
Christopher Currins's Avatar
There's the culprit. Like previously mentioned, open penetrations in exterior walls and extreme moisture. With that low amount of insulation in attic, probably none in the the walls.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 3/5/10, 9:52 PM
Vaughn Hill's Avatar
Vaughn Hill Vaughn Hill is offline
That roof sheathing by no means looks only six months old.
Monroe Home Inspection
3168 Orchardale st.
Monroe,MI 48162
734-289-2190
Old 3/6/10, 8:53 AM
Banned
There's culprit #1!
#2 would be NO AIRSEALING at the ceiling level.
#3 may be lack of good interior ventilation such as quiet, strong bath fans on timers and range hood vented to the outside .
Look for interior sources of moisture such as:
-Is the basement/cralwspace dry and is a moisture barrier at the ground/concrete floor level?
-Do they dry clothes inside as an energy saver?
-Is the dryer ducting leaking at joints?
-Any hobbies/other actions producing moisture?
-High #'s of plants?
-Large uncovered aquarium/s?
Once you take care of the above, the existing roof venting may be adequate!!!
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 7:31 AM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 3:59 PM
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 1:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 2:19 AM
