At least that does not seem to be the problem. Appears to be baby wipes. At least a ton of them. Does anybody have a clue as to how to dissolve or remove. So thick they can not be pump. Actually so thick it appeared to be solid ground and yes it would support someone. Had to take a spud bar to break loose. Any suggestions for the sellers.
Thanks for any help Last edited by gbrown2; 2/24/10 at 5:07 PM.. |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What the heck are you talking about ??
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Sounds like a load of c--p if you ask me.
Isn't it a bit early for Miller Time?
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Yeah, yeah, spud bar is the best move...or did you mean a spud wrench, like an Iron Worker would use?
Drew Levy NJ# 24GI00101400 Radon # MET12929 Homespect LLC (609) 668-7588 http://www.homespectllc.com http://www.philadelphiahomeinspection.net http://www.southjerseycommercialinspection.com http://www.haddonfieldhomeinspection.com http://www.abseconhomeinspection.com http://www.willingborohomeinspector.com http://www.thehomeinspectioninstitute.com |
Are you talking about in a septic system?
Or maybe a potato field ??????
NACHI #03120124 www.aplushomeinspections.net Proundly Serving S.E. Wyoming & Western Nebraska "Learn from the mistakes of others, Life is to short to make them all yourself" |
kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm glad you clarified because that was my first question.
wouldn't touch it with a 10' spud bar
its a sleever bar or a spud wrench, not spud bar
I just went thru a colonoscopy
Setic inspection. Tank full of solids including a lot of baby wipes that were use instead of toilet paper. Have any useful suggestions?
Recommend regular pumping and not putting anything down the drain that isn't toilet paper, or hasn't been passed through a body first. If what is there won't pump out, recommend that they get a quote for repair and possible replacement of tank. The sellers messed up. They should have known better than to flush other stuff.
Do any of you have an intelligent response or is this a picture of the true mentality of Inter NACHI home inspectors? It is no wonder why most people have a hard time seeing the value of the home inspection industry.
