I know that "double" lugging is not Okay but I have never been told that this is a problem so I guess it is Okay.
Robert Sole, CMI 407-637-7288 Florida license numbers HI 169 and MRSA 92 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com Check out my blog orlandohomeinspections.info/ REMinspections.com OrlandoHomeInspector.net |
Unless the terminal is rated for multiple conductors it is not OK.
You've got to be kidding.....
You've got triple taps on the main SE that need to be separated onto their own breakers. |
That is not okay.
There, you've been told. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I was only joking. The previous homeowner had added a separate panel to install an A/C and just tapped into the main breaker to power it. He then added another panel for a storage building and again tapped into the main breaker. I guess he ran out of things to add or who knows what it would look like.
Good call then. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
It is, it is, it is. Peter Doane Realty Check Inspection Service NACHI ID# 05120681
cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
SURE thats fine....just make sure the insurance is paid up and that you dont actually sleep in that house. KIDDING scary to say the least! |
Peter,
I've heard timae and again that "double lugging" is a problem. I never once was told that "tripple lugging" was!! Robert Sole, CMI 407-637-7288 Florida license numbers HI 169 and MRSA 92 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com Check out my blog orlandohomeinspections.info/ REMinspections.com OrlandoHomeInspector.net |
I was trying to show what I found and add a little humour to the post. Sorry to everyone if I screwed that up.
All Auxillary Panels Must Leave The Main Panel Via An Identified Ciruit Breaker! Nec.
That is what we call a time delay fuse in the Arson industry!
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Guess this isn't so bad then!
