I'm trying to get more efficient with my inspections as far as time is concerned. I've done about 20 inspections since I've been licensed and they all seem to take about the same amount of time regardless of the house. Most of mine are about 1900 sq ft, some with crawl space and some without.....no basements here in Louisiana. It always takes me about three hours (the exception is my very first one took about five hours because I triple checked everything lol). My routine is getting better. But I wanted to hear about other's routines.
Do you typically go room to room and knock out everything in that room, or do all electrical then all plumbing etc.? I do exterior, then roof, then move inside and get kinda random. Thanks for the help guys. |
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I will typically do the exterior, roof, when I go to the inside I setup my laptop in the kitchen and do the kitchen first, then I go high to low (attic down to the basement). If there is a crawlspace (rare for my area) I do that and the garage last.
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Hey Colton I live in Fl. and like you we don't have basement and it take me about 2.5 hours to do an inspection. I start with the roof, and then do everything outside except the sprinkler system but I get to that later, and then move into the garage because most of the important components are there like the electrical panel, water heater, air air handler, garage components and then I go to my computer that I set up in the kitchen and input everything up to that point. Then I start with the kitchen and move to the living rooms than the bedroom's and finally the attic and then back outside for the sprinkler system which allows me to cool down a bit after sweating in the attic. Hopes this help and good luck.
Set up in the kitchen
1. Start at the exterior front door and walk counter clockwise around the house 2. exterior of the roof second trip around the house. 3. Kitchen, from the kitchen I then inspect the first room off of the kitchen and continue in that fashion untill all rooms have been checked 4. mechanical room (Water heater, furnace, service panel, water meter....) 5. attic 6 crawlspace I always save any attic or crawlspace for last as I do not want to drag any potential dirt or debris through the house. Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
Exterior foundation walk around
Crawl space with a complete protection unless really dirty then last. Garage Roof Attic and ventilation at the hatch. Kitchen Livingroom Dining room Bedrooms Bathrooms top floor Downstairs rooms Laundry and furnace room Check structure at the ceiling Electrical panel last. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 11/22/11 at 1:39 PM.. |
1st - Grounds, exterior, roof
2nd - to the basement(95% have them in Chicago Area), HVAC, Plumbing, Electric 3rd - Kitchen, 1st Floor 4th - 2nd floor, Attic, usually finish up with the garage Setup is in the Kitchen. I use a tablet PC convertible; part of the time it's with me, sometime left in kitchen. Dan Musielski Engineer/Inspector IL Lic # 450.0002229 Assured Home Inspections "The NEW Standard in Inspecting" Batavia, IL 60510 Phone 630.745.0573 www.InspectThatHouse.com See us in the Fox News Channel! FOX NEWS Shattered Dreams http://www.foxnews.com/us/2010/10/13/foreclosure-mess-thickens-experts-fear/ |
Walking around the exterior first gives you an overall prospective about the property; age, maintenance, exterior foundation, etc. You will then get a head start on what to look for on the inside. I then go to the kitchen, main floor, upper floor, (flush lots of water through toilets, showers, drains) room to room, then on to the basement (main panel) or crawl space. This way you can look for drain leaks. Most of the inspections I do here have basements. Garage/attic is last. I always end the inspection by inviting my client to see the attic. It brings closure. During the process, I take notes on my lap top, and print the reports on site. Total is 3 hours. Larger/older homes take a little longer. If the owner is there, we go off-site or email reports next day.
Pretty much as Dan M. does, and most other inspectors. Buyers are pretty much up-tight about the procedure, so often I give them a maintenance tip, or a small "funny" to ease the stress. Just a small question often gives you more information about how to handle the buyer, and perhaps add a safety tip to your report if they have kids. "What to you do professionally?" "Do you have any children?" "Gee, this is a nice big master bedroom closet. Where is yours?" Male buyers always laugh at that one. "This home has tilt-out thermo windows. Is it OK if I teach your husband how to clean windows"? I have a bunch of them. CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
[QUOTE=gfarnsworth;843936]
"This home has tilt-out thermo windows. Is it OK if I teach your husband how to clean windows"?/QUOTE] I never ask...I just call the husband to the window and start with the instructions. Somewhere along the line I'll give a knowing wink to the wife...she gets a kick because he's learning to clean the windows. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Thanks for the ideas. I should clarify one thing though. I take field notes during the inspection so after the 3 hr inspection I still have to go generate the report...that usually takes a little while too. I'm thinking about some software options but can't really spend a few hundred dollars on a PDA and software right now.
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
1-Start inspection on computer(Internet)
2-Look at houses approaching house to be inspected 3-Pick a corner on exterior walk all the way around entering conditions as I see them. 4-Garage start one corner go all the way around until I get to where I started (again enter as I go. 5- Roof 6- Lower floor enter door go left or right follow the wall, enter as I go until I come back to main entry. 7- If one level then I do attic and crawl if there is one 8- If two level do stairway. At top go left or right, enter as I go until I get back to where I started. 9-Attic 10- Crawl if one 11- Get papers signed, review collect payment, leave |
I let the time of day and weather dictate my procedure...
If it's an early morning start, I do the inside first allowing time for the grass to dry. However, if it looks like rain, I get the outside done first, then move indoors. If it's an afternoon inspection, I too like to do the outside first. The attic is always last. I wear shoe covers over my work boots (yes, I like to wear work boots... see other posts about this hot topic) always when I'm indoors. This is why I let the grass dry if I can before I move inside. As far as my room plan... I do it by group by group, not room by room. This means I may go into the hall bathroom several times... Once for electrical, once for plumbing, once for wall, ceiling and floor, etc. but this is mainly because that is how my program is set up for inspections, and not really my preference. I spend about 2-1/2 hours for an average inspection. Rarely more than 3 hours at a home. Eric W. Augustin A1 Certified Home Inspections If you can't explain it simply, you don't understand it well enough. Albert Einstein
Roof (so client can review PIA if they did not previously)
Exterior Garage (now to the interior with indoor shoes)... Appliances (need to start dishwasher ASAP but don't want to leave it unattended while outside) Then down to basement (fresh from outside so that I can smell any musty, mildew, moldy smells if present)... Structure Electric (panel etc.) Plumbing (water heater etc.) Heating A/C Fireplace Interior (from basement to top floor towards attic) Insulation / Ventilation (inc. attic which is the dirtiest part of the inspection). Roof and exterior sometimes left till last if the weather is nasty and I think it may improve over the next few hours. Rick Strand, CPI CAHPI Associate Strand Home Inspections Inc. Calgary, Alberta, Canada Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Exterior
Roof, basement (most of the time) heater, water heater, electric panel kitchen bathrooms, Attic and crawls are left for last. |
Inspections up to 2000 sq ft typically take me 3 hours or so. I don't always have a set routine. Clients tend to throw me out of any routine. One piece of advice is to check the attic before you walk on the roof. I have seen sheathing decay so bad, that if I had walked the roof first I may have visited the master bedroom before I wanted to.
1. Street photo
2. Go inside turn on dishwasher if it applies 3. Unlock all doors if it applies 4. Do a lap around home, look at eves ect..watch for dry rot ect 5. Roof 6. Exterior 7. Garage if attached 8. Bedrooms, living, dinning ect. 9. Bathrooms 10. Kitchen/laundry 11. After all interior is inspected, I do attic 12. Turn on all faucets, shower, ect and do crawl space last if it applies |
| This is what change looks like.... | kpierce | Legislation, Licensing & Legal Issues for Inspectors | 81 | 4/4/10 8:57 PM |
| Washington HI licensing information from DOL | hmiller | Legislation, Licensing & Legal Issues for Inspectors | 182 | 10/3/09 12:14 AM |
