Old 4/4/09, 6:51 PM
Ryan Busch Ryan Busch is offline
Please Note: Ryan Busch is a non-member guest and is in no way affiliated with InterNACHI or its members.
Lightbulb outlet above h2o ???
This outlet is non GFI. Home is 1978. My question is this outlet above H2o supply ok?
tnhi@q.com
Find an InterNACHI certified Florida Home Inspector (and anywhere else in North America)
Old 4/4/09, 7:38 PM
Default Re: outlet above h2o ???
I recommend all outlets around water be gfci protected for enhanced safety. You can too.
Larry Kage, CMI
231 929 3525
Old 4/4/09, 8:43 PM
Terry Clayton Terry Clayton is offline
I believe the NEC still requires GFCI with in 6' of water
Old 4/4/09, 9:26 PM
Jeffrey R. Pope's Avatar
The question is way too vague for an accurate answer, but there is no longer a 6' reference in the NEC.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/4/09, 10:44 PM
I believe you are correct Jeff.
It is my understanding that all Kitchens and Bathrooms , and garage shall be GFCI protected and the rest of the House is on AFCI's.
Old 4/4/09, 11:02 PM
Jeff when did this come about. I found this on the net from 07. thanks
http://ecmweb.com/mag/electric_branch_circuits_part_2/
Old 4/4/09, 11:23 PM
William J. Decker's Avatar
No. Current standard is ALL recepticles above countertops or on islands.
Pretty much every one except serving the fridge or on the walls (not above countertops).
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 4/4/09, 11:42 PM
I got to get me the new book, thanks to all
Bathroom outlet near floor: GFCI mthomas2 Electrical Inspections 3 4/13/07 10:35 PM
Testing a dryer outlet acox Electrical Inspections 14 7/27/06 10:51 PM
