I am curious if anybody has any recommendations for a pinless moisture meter (obviously, one that works well on drywall). Information is a little hard to come by on the web, and I'm looking for an alternative to my pin meter that marks the walls when used... Hopefully for a couple hundred or less? Thanks in advance.
| Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
This cheap gadget works fine, if your looking for a inexpensive product.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
price was good, but 1 year later doubts Review by Jeff I am having problems now with the readings. I keep the batteries out of it when not in use. I went to use it and am showing 0% on many woods that should be in the 6-8% range. Also temp is showing 73 when it is 63, and when I put it next to my laptops output fan it is showing 73 when it should be closer to 80+... So I have my doubts that it is still working. (Posted on 12/1/10) Good but not great Review by Robert Lowman Very good for the price. Battery life was short and reading above 42% would be good. (Posted on 11/24/10) Would recommend to friends Review by Love it Needed a moisture meter to determine how seasoned my firewood is. This unit is simple, small and works great. Best of all it's affordable. All other moisture meters I looked at were $100+. Additional function includes thermometer ability. Haven't used this at all. (Posted on 11/13/10) Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Thanks so much for the help so far. To clarify, I suppose I am looking first and foremost for a professional quality product, but along the lines of entry-level, if you know what I mean. I'm sure a lot of you guys have gone through a few of these, and I'm looking for the best one that 200 to 300 can buy! Thanks again.
http://www.ryobitools.com/catalog/ac..._tools/E49MM01
You can get this at home depot as well. I believe around 50 bucks. works well on many different surfaces. Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
When in doubt, check Craigslist. But not just locally. Here is the link to "Craiglook" that checks all Craigslist ads nationwide. http://claz.org/
That is where I got mine, brand new from a pawnshop. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Why skimp on tools? Get a Protimeter Surveymaster and be done with it.
Chuck |
Thanks for all the advice everyone. After much research and good advice, it does seem like the Protimeter SurveyMaster is the way to go. Tramex makes a pretty good product also, but the Protimeter seems to have a lot more experienced users singing its praises! Thanks again for your help.
I've been using this Moisture Meter that I did get off of eBay. I don't normally find my tools here, but I got it and am very pleased. It seems to be very accurate in both Pin and Pinless modes.
Eric W. Augustin A1 Certified Home Inspections If you can't explain it simply, you don't understand it well enough. Albert Einstein
5144 Atwood Terrace Inverness, FL 34452 352-212-3576
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County Last edited by sstanczyk; 1/27/11 at 1:17 AM.. |
I didn't think so but .... you never know.
Survey Master Dual Function Moisture Meter
| Fighting Mold — The Homeowners' Guide from CMHC | mkyriacou | IAC2 Indoor Air Forum | 1 | 9/17/09 2:32 PM |
| Moisture Management | mcyr | Exterior Inspections | 15 | 9/8/08 12:11 PM |
