Old 10/3/11, 1:56 AM
Jim Ruxton Jim Ruxton is offline
Please Note: Jim Ruxton is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Is this pipe leading to buried oil tank?
Hi,
I was wondering if anyone knows what a pipe like this coming into a basement wall in Hamilton ON could be. It's about 1.5 " in diameter. It is about 30 inches below ground level. Sorry it's not a great photo. My fear is, it could be a buried oil tank? If it is, the tank must be on it's side because of the depth. It is near the front of the house. There are no pipes coming out of the ground outside the wall. There is a paved walkway covering the area where the tank would be if it is there. I'll probably bring in a metal detector or radar system but if anyone has any thoughts what it is other than a buried tank I would be interested to hear the theories. I'll also see if there are any tank removal companies that can safely remove the cap and check inside. Thanks for any thoughts.
Jim
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/3/11, 6:33 AM
Wayne B. Wilson's Avatar
Default Re: Is this pipe leading to buried oil tank?
It could be a vent pipe for a old oil tank . is this in the Basement?
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 10/3/11, 8:19 PM
Mark Raumikaitis Mark Raumikaitis is offline
There is another possibility that needs to be considered. Here in NH I sometimes find old abandoned natural gas lines. The local utility has moved the gas meters to the exterior of the home from the basement and they leave the old line passing through the wall. Is natural gas available at the location? Also the possibility of a drain line going to some type of dry well. Hard to say without seeing it in person. As to the underground tank...I usually only find dual copper supply and return lines from the old underground oil tanks...the fill and vents pipes were usually found at the exterior. Any answer may fit and you should continue to due your due diligence. Be careful opening that cap without knowing what is on the other side.
Mark Raumikaitis, CMI, NH Lic #133
HomeCheck Professional Home Inspections LLC
Derry, NH
603-432-3211
Inspecting New Hampshire and Southern Maine
http://homecheckhomeinspections.com/
"Always think long term, do not be influenced by short term thinking or rewards."
Old 10/3/11, 8:31 PM
David A. Andersen's Avatar
Let me go get my x-ray glasses.
Can you back up a little and take that picture again?
BPI# 5015804
Old 10/3/11, 8:50 PM
I doubt a 1.5 inch Gas line . but it could be i guess.
Wayne Wilson
865-256-1490
Old 10/3/11, 8:52 PM
And outside the wall too.
David here i thought you had a red cape and SI on your shirt lol
Wayne Wilson
865-256-1490
Old 10/4/11, 5:16 PM
Joseph Hagarty,  CMI's Avatar
Old Steam Heat supply piping?
(dating myself now)
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 10/4/11, 5:39 PM
(dating myself now)
Could have been worst , you could have said speaking pipe .
Wayne Wilson
865-256-1490
Old 10/4/11, 7:49 PM
(dating myself now)
What..you're not dating girls anymore?
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
vent pipe in return dlee2 Inspecting HVAC Systems 2 2/18/10 12:51 PM
Make $50.00 More Profit per Inspection with Septic Tanks ebeahm1 Ancillary Inspection Services & Additional Topics 6 8/20/09 1:38 PM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 6:40 PM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
