| Find an InterNACHI certified Arizona Home Inspector (and anywhere else in North America) |
I always thought that the MFG. home was built on a steel frame with axle's and when they set the home they took the wheels back with them.
Over the years there have been legal issue's in regard to modular and Mfg. home's, especially where protective covenants are concerned. |
Steven C. Meyer is a non-member guest and is in no way affiliated with InterNACHI or its members.
(don't think she liked me much after that!) Ended up buying a stick house in Aurora, Co. Much better deal. So, all ended well!! As a side note, the realtors husband was in the business of "installing" manfactured homes and did not appreciate my opinion of them!! Win a few, lose a few!! |
Where it says manufactured homes are cheaply constructed is not true. Most manufactured homes have #1 grade lumber and 2x6 walls and are built better than most stick built homes. I just saw today a cheaply built modular home, so it all depends on who manufactures them.
Also manufactured homes are commonly put on foundations so where it says has no foundation may need some clarification. In Missouri, a manufactured home model can be classified a modular home if the building plans are approved by the state before manufacturing. The steel frame and all can be slide on to a foundation and can still be called a modular home. |
What does a tornado and an Arkansas divorce have in common?
Answer: Somebody is going to lose a mobile home.
My favorite thing about modular homes is they are square. Makes floor covering a breeze to replace.
dharris is a non-member guest and is in no way affiliated with InterNACHI or its members.
They are cheaply constructed, small, and are held to less stringent standards than modular and site-built homes. Their obvious advantage is their mobility and affordability, factors that allow buyers to make home purchases without serious monetary or geographical commitments. They are available in three sizes that escalate as follows: “single wide”, “double wide” and “triple wide.” In addition, manufactured homes
Cheaply built I can only guess you got it from a wantta be builder that lost a sale to a Mfg home, and or doesn't have a clue about the construction of a Mfg. home. Some of it must have come from that former builder turned to a wannta be home inspector, Stevie boy Myers Structurally Approved. Have you ever seen a site built home being hauled down the road at 60 70 mph. Did you ever see EVERY phase of a site built home inspected several times by the manunfacture, and by a state inspector before the next phase could be completed, or before the home could be delivered to the customer. They are difficult to expand or improve; Guess if you believe the other comments, you would also believe this. |
Are not required to be approved structurally approved; Double talk .
Do not have a foundation; Are not always required to have a perimeter foundation, but, are sometimes set on piers with tie down straps and surrounded with Vinyl or Aluminum Skirting. Note: Some lenders require a foundation certification by a qualified structural engineer. "It's not what you believe that matters...it matters what you believe!" |
Modulars are set in place by a crane.
Good article.
"Mobile homes" have a title like a car or a RV and are transferred at the Secretary of State or DMV. "Modular homes" have a Deed like a house, and are transferred that way. |
I assume you inspected a few in your days. How many defects did you find on mobile home or manufactured homes, that were related to manunfacturing defects, opposed to defered maintance, and defects/improper repairs or remodeling caused by the home owner, or improper set ups. Granted lower cost materials were used on older Pre HUD homes, when they were called mobile homes.. Truth is, Since reguation and enforcement of construction on mobile homes by HUD, Now called Mfg. Homes, the chance of finding a mfg. defect is almost nill compared to what one will find on a site built home. |
The winner is now praying for a tornado!! |
As long as you have run over your framing square with your truck!!
| Please proof this article: Fiberglass Insulation: History, Hazards, Alternatives | gromicko | Miscellaneous Discussion for Inspectors | 0 | 3/20/09 11:57 PM |
| Manufactured vs Modular How do you tell? | jhittle | General Inspection Discussion | 18 | 8/14/08 9:18 PM |
| Roy the proof you asked for | wdevries | Canadian Inspectors | 55 | 7/8/08 11:30 AM |
| Learn the Differences: Site-Built, Modular, Manufactured/Mobile Homes | jsieg | General Inspection Discussion | 10 | 12/23/07 12:20 AM |
| Are electricians supposed to use these tools as per 70E? | jtedesco1 | Electrical Inspections | 27 | 12/15/07 4:40 PM |
