Old 1/5/10, 11:49 PM
kpierce's Avatar
kpierce kpierce is offline
Please Note: kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Plumbing vents
Came across something new today. Combined plumbing vents (not stacked). Code check says "two or more" may be combined as long as they maintain 1/4 in. per foot rise. Is there a max number of vents that should be combined? Also, what about max length on the branch? I assume as long as the rise ratio was maintained it wouldn't max out.
Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America)
Old 1/5/10, 11:54 PM
Default Re: Plumbing vents
Ask your local code inspector. We do not quote codes.
Old 1/5/10, 11:57 PM
kpierce's Avatar
You wouldn't write up combined plumbing vents that had a negative/even grade on the branch?
Old 1/6/10, 12:00 AM
kpierce's Avatar
Have you ever read this message board? There's lots of guys who love to quote code.
Old 1/6/10, 12:06 AM
Then, read the code check, or ask the Blue Man Group.
Old 1/6/10, 12:08 AM
Christopher Currins's Avatar
Is this what your talking about?
When fixtures are connected to one horizontal branch through a double wye, a sanitary cross in a vertical position, or a manufactured fixture carrier, a common vent for each 2 fixtures back-to-back shall be provided. (See Appendix K: Illustration BB.)
Section 890.ILLUSTRATION BB Fixtures Back-to-Back in Battery
(Referenced in Section 890.1520(d))
Christopher Currins
Certified, Licensed
Old 1/6/10, 12:15 AM
That is an exact Blue Man Group PVC instrument blue print.
Old 1/6/10, 12:21 AM
kpierce's Avatar
Essentially. However, one vent intersects perpendicularly. Basically, three bathrooms, one vent goes straight up and out, one comes up and over and connects to the first one mentioned. The third comes up, over and joins the second one perpendicularly.
Old 1/6/10, 12:25 AM
kpierce's Avatar
That legislation has made you one bitter man.
Old 1/6/10, 12:30 AM
As long as they're sized properly I wouldn't see a problem. But, of course, I'm not a plumber.
Christopher Currins
Certified, Licensed
Old 1/6/10, 12:38 AM
kpierce's Avatar
Yeah, for this setup, I was thinking as long as they had a proper rise and size, it wouldn't be a problem. Just got me thinking about max lengths and combinations and thought I'd post. Should have remembered that this MB is mostly filled with bitter old men with thorns up there asses cuz they aren't creative enough to diversify in a rough market.
Old 1/6/10, 12:57 AM
I agree, there were about 50 members logged in when you posted the question and all you got was an answer from a non-member and a grumpy old one. Nothings changed.
Christopher Currins
Certified, Licensed
Old 1/6/10, 1:28 AM
Nick Gromicko's Avatar
I believe you are describing a "circuit vent"...
...in which case a maximum of 8 fixtures are permitted.
The maximum length of the branch is dependent on the size of the trap (the bigger the trap the longer the distance to the vent can be).
The minimum required diameter of a branch or circuit vent is 1/2 the the drain served but at least 1-1/4 inches in diameter. And bigger in diameter if the vent is more than 40 feet long.
If you are talking about the slope of the drain... no. 1/8-inch per foot rise (slope) is fine for 3" and 4" traps.
Find a Home Inspector
Old 1/6/10, 1:31 AM
kpierce's Avatar
No worries though. I didn't "need" to know an answer. Just thought a little dialogue on the subject would be interesting.
Old 1/6/10, 1:34 AM
kpierce's Avatar
Originally Posted by gromicko View Post
I believe you are describing a "circuit vent" in which case a maximum of 8 fixtures are permitted. The maximum length of the branch is dependent on the size of the trap (the bigger the trap the longer the distance to the vent can be).
Thanks for the response, Nick.
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
