I've began marketing the Pre-Listing inspection hard in this area. None of us are perfect and I was wondering how any of you handled the issue when the Buyer inspection turned up an obvious issue that "was not recorded" in the Pre Listing inspection just days before? This may be a visible moisture damaged rim joist or safety rail missing not a component that was damaged or quit working since the pre-listing inspection.
Any good disclaimers? Rick A. Harrington Patch Independent Home Inspections, LLC Serving Columbus and Central Ohio Certified Specialist - Infrared Residential Inspections Advanced Certified Level 1 Thermographer Certified Mold Inspector State of Ohio Licensed Radon Tester http://www.patchhomeinspections.com http://www.centralohiohomeinspector.com http://www.columbusohiohomeinspector.com http://www.thermalimagescanning.com |
1. Glad to see you got a pre-listing inspection.
2. You should use the www.MoveInCertified.com program. 3. Here ya go... "Note: Just as no two home inspectors and no two reporting systems are alike, no two inspection reports, even if performed on the same property at the same time, are alike. This pre-listing inspection report was performed for my client, the home seller, with the cooperation and assistance of my client/home seller. It assumes full disclosure on the part of my client/home seller. My client may choose to share my report with others, but it was performed solely for my client. And although ABC Inspections performs all inspections and writes all reports objectively without regard to the client's personal interests, additional fresh inspections, which of course would reveal and report matters differently, should be considered." Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
If you missed it, you missed it. You can't disclaim that, but you can turn it over to your insurance. . .
Why do you need a disclaimer? I write every report according to my findings and could really care less what somebody else reported, or missed. Personally I wouldn't even look at another report done before mine, I would let who ever is involved in the transaction make that judgment based on what I see. If the people involved want to know anything about your report I'm sure they will certainly be in touch with you. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Rick
Did you do the pre-listing inspection or the buyers inspection? With the "what if" I'm not quite sure which one you did. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
In this scenario, I would have done the Pre-Listing inspection. This has not happened. I was just trying to prepare for that situation so I would know what to do.
I need to know how to answer that question when making the presentation to the groups that I get in front of. Rick A. Harrington Patch Independent Home Inspections, LLC Serving Columbus and Central Ohio Certified Specialist - Infrared Residential Inspections Advanced Certified Level 1 Thermographer Certified Mold Inspector State of Ohio Licensed Radon Tester http://www.patchhomeinspections.com http://www.centralohiohomeinspector.com http://www.columbusohiohomeinspector.com http://www.thermalimagescanning.com |
Many inspectors will disagree, but I'm not afraid to let people know I'm insured. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Good answer and that is what I'll have to use.
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here in California, dryrot damage to a rim joist would also be of interest to the termite company. Since it would be listed as a section 1 item, again the seller would most likely be responsible for the repair of same. Good Luck! Last edited by whandley; 11/9/07 at 1:07 PM.. |
| List Your Business For Free | jbowman | Miscellaneous Discussion for Inspectors | 17 | 8/13/06 1:29 PM |
