Old 4/24/07, 3:37 PM
poliner's Avatar
poliner poliner is offline
Please Note: poliner is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Probem with Surveymaster (Protimeter)
Just finished an Inspection,
damn mositure meter playing up, sensor goes beserk, does not seem to pick up lower levels of detection. On search mode CF REL> Comes up.
Anyone else had errors with this type of meter?
Any input gratefully recieved,.... its like loosing a limb being without it
Old 4/24/07, 5:56 PM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Default Re: Probem with Surveymaster (Protimeter)
I had similar problems once before...changed out battery...and good to go.
If it's not the battery, GE will recondition it for around $100.00
Good luck!
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 4/24/07, 11:54 PM
jkormos's Avatar
jkormos jkormos is offline
Did you use the calibration tool that was provided with the meter?
Joe Kormos
A-1st Look Home Inspectors Inc.
630-201-0933
Your 1st Choice in Property Inspection Professionals
www.a-1stlookhomeinspectors.com
www.a-1stlook.com
Let us look before you buy...for peace of mind
“Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford
Old 4/25/07, 10:35 AM
poliner's Avatar
Yes on the calibration it was OK, measure mode operated. Although it had a new battery I changed it, seemed to do the trick.
The fault was on search mode. In the manual certain conditions that come up "flashing" need attention/ contact with supplier.
I was thinking allthough HI tools are fairly basic if they go wrong it probably is not a quick fix.
Just reminded myself to get back up tools in.
Thanks for input
Old 4/26/07, 9:56 AM
rwand1 rwand1 is offline
You should also verify the meter is working by placing a wet rag under a piece of 1/2" wood. They are not foolproof and it is possible to get erroneous readings if there is metal under the area being tested.
Protimeter Aquant error sbyrnes General Inspection Discussion 0 8/7/07 10:55 AM
Your chance to get a Protimeter Surveymaster sbentley Miscellaneous Discussion for Inspectors 0 6/7/07 8:10 PM
