I had a client as me if I can determine if his residence is level... I told him
I could not. The client mentioned that another Inspector on a different property gave him measurement as to the property being level. Anybody ever heard of this? Who would be the proper contractor to do this? David |
| Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
rspermo is a non-member guest and is in no way affiliated with InterNACHI or its members.
David,
Do you mean the residence's floor/foundation? Many inspectors that do new construction inspections for builder's warranty companies use a digital water level. You can take measurements all ove the house while using a base position as your point of origin. |
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Remember properties are not REQUIRED to be perfectly level.
Chuck |
thanks for the feedback.
David |
I just roll a ball on the floor.
dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sounds like a fluff job by the other inspector. But why couldn't you do it. Check the floors with a regular 4 footer. (Or even a 2 footer which I do if a floor looks out of whack). If they want more either a water level, or a builders transit. Easy if you have any building back ground.
you can buy a self leveling laser for about 100 bucks. why couldnt you do it?
| Standards question | jcahill | General Inspection Discussion | 55 | 6/30/09 8:14 PM |
| Property Management Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 0 | 1/9/09 3:21 AM |
| Level I Certification Process | dbowers | Thermal Imaging, Infrared Cameras & Energy Audits | 40 | 10/17/08 5:05 PM |
| Commercial Property Conditions | mcyr | Commercial Inspections | 11 | 5/5/08 8:50 PM |
