Old 5/20/10, 9:08 PM
David C. Macy's Avatar
Default PVC soffit baffles
Are PVC pipes considered an acceptable material for a soffit baffle. I would say no, but I am asking.
And since I am asking inspection questions, a speaker recessed in the common wall would be a breech in the fire protection correct?
And since I have you here what is with the 2 PVC terminations filled with gravel. I typically see clean outs with pvc caps.
Thanks for your time.
ID:	37077   pvc-soffit-baffles-163410-020-small-.jpg.jpg
ID:	37078   pvc-soffit-baffles-163410-002-small-.jpg.jpg
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/20/10, 9:29 PM
prichardson's Avatar
prichardson prichardson is offline
Please Note: prichardson is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: PVC soffit baffles
North Carolina Building Code states-"A minimum of 1 inch (25mm) of airspace shall be provided between insulation and the roof sheathing"
And I beleive most state codes are pretty much the same. So unless he lines up pipe all the way between rafters, this won't work.
code-" any penetration of rated assembly must be protected and sealed as per penetration detail" Fire rated damper and fire caulk.
I don't think the speaker cover is a fire rated damper.
Don't have a clue about the 2 pvc pipes!
Old 5/20/10, 9:40 PM
Hi. David.
Innovation at it's best.
That leftover drain pipe is only providing 12.56 sq. in. of air for ventilation compared to a normal proper attic baffle vent that allows approx. 18.7.
So the need to provide the 1/300 ventilation might not be met.
The two to one rule should be followed for attic ventilation when possible.
50% in the soffit and 50% out the other vents.
The NFPA allows some box penatrations in separation walls and also dictates that outlet boxes and back boxes should not be in the same bay on different side of the wall. Meaning back to back.
Was that a 1 hour rated wall?
Could you tell them to put caps on those cleanouts.
Could be someone's bright idea of perculating surface water through the stone without clogging the underdrain. Who the hell knows.
I'm sure others will chime in David.
Old 5/21/10, 1:29 AM
Banned
No! No! No!.....it's 1:30 AM here; others are going to bed!!
Old 5/21/10, 9:52 AM
Thanks for the responses. Appreciated.
Time to wake up!!
Baffles bhartley Interior Inspections 5 8/22/09 11:21 PM
Way More Intake To Supplement Minimal Exhaust Ventilation? Ed Fako Exterior Inspections 1 12/19/08 7:07 PM
White Soffit Cleaner gporter General Inspection Discussion 7 7/8/08 8:13 PM
Soffit Stains vsantos Exterior Inspections 5 5/22/08 9:01 AM
Soffit Baffles Erol Kartal Interior Inspections 15 3/11/08 12:14 PM
