Just wandering how many out there fill every bath tub to the overflow drain to check it out? I think that would take a lot of time and water when there are two or more tubs. I've heard of stories when the overflow drain is not hooked up properly but should we test everyone?
Thanks for your input Sid |
Tubs no. Sinks and vanity basins yes. Have found many clogged and leaky overflow drains,
"You expect the best . . We'll provide no less" Stephen Enomoto Horizon Home Inspection LLC www.horizonhome.net steve@horizonhome.net President: Hawai'i NACHI (O'ahu Chapter) |
I only fill up whirlpool to test jet pump.
Same as both above... Tubs no, check the stopper. Sinks, fill 'em up...
- Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
I do...although I recommend that you watch it closely!
Harvey Gordon - President - FloridaNACHI (The OFFICIAL Florida State Chapter of NACHI) SEFloridaNACHI (Serving NACHI Members in Martin, Palm Beach, Broward, Miami-Dade, and Monroe Counties) ______________ Questions or Comments about FloridaNACHI or if you would like to start a LOCAL Florida Chapter may be sent directly to me at hgordon@fl.nachi.org ______________ |
Bathtubs, no. Sinks, yes. Spa tubs, only enough water to test the jets.
Never bathtubs, most of the times, sinks. If the overflow on a bathtub leaks, it may take some time before it starts to work through the ceiling below.
| Complex challenge with bath exhaust fan - need help with solution! | Bill Featherstone | Electrical Inspections | 11 | 11/5/07 2:16 PM |
| Another GFCI Question | rnewland | Electrical Inspections | 2 | 6/16/07 3:25 PM |
| WA State Legislative update | hmiller | Legislation, Licensing & Legal Issues for Inspectors | 153 | 5/5/07 12:55 AM |
| Plumbing vent Routing Question | kweiss | Plumbing Inspections | 7 | 11/1/06 10:57 PM |
| Answer to a common question about GFCI's | jtedesco1 | Electrical Inspections | 4 | 1/12/06 10:29 PM |
