Not having a copy of the NEC with me, I ask a little assistance.
Is an under-the-kitchen-sink outlet, normally used for a disposal, required to be a GFCI protected outlet by the Natl Elec Code? Code Check says: "Receps within 6ft of wet bar, laundry, or utility sinks"...that's as close as it comes, but as we know, sometimes close isn't good enough. Thanks! |
| Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thank you! I think I looked everywhere except there!
I didn't look at Marcels references, but the answer is "no." The receptacle outlets beneath the sink do not require GFCI protection.
| GFCI Question | lrollins | Electrical Inspections | 2 | 3/3/10 8:04 PM |
| GFCI won't trip by tester | rstufflebeem | Electrical Inspections | 22 | 3/22/08 8:10 PM |
| More GFCI info from U/L | Greg Fretwell | Electrical Inspections | 9 | 12/4/07 8:33 PM |
| GFCI Question | jvogan | Electrical Inspections | 4 | 8/25/07 2:28 PM |
| Can an AFCI offer GFCI protection | gbeaumont | Electrical Inspections | 19 | 7/6/06 11:45 PM |
