Old 5/14/10, 11:07 AM
David N. Hubler David N. Hubler is offline
Default Radon testing on granite
Has anyone used the Air Check PM1703M radiation detector for testing Radon levels in granite? If so, at $495.00 to purchase the unit, has it been a profitable addition to your services offered?
I am open to anyones thoughts on addidng a service like radon testing as an ancillary service.
Here is a link to the unit: http://www.radon.com/products/pm1703.html
David Hubler
Capstone property Inspections
http://www.capstonepropertyinspections.com
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/14/10, 5:07 PM
Greg Keene, CPI's Avatar
Greg Keene, CPI Greg Keene, CPI is offline
Default Re: Radon testing on granite
There really isn't any need to check for Radon on granite counter tops. Even the EPA came out with a position paper (about 2 years ago I think) on it saying it is not necessary. I can't find the doc but I read it once.
Greg Keene
Clear Choice Home Inspections
Evergreen, CO
303-674-3234
greg@clearchoice-hi.com
Old 5/14/10, 5:55 PM
Most granite tops are sealed anyway.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 5/14/10, 6:24 PM
mnahrgang's Avatar
Even if they weren't the only radon that could escape would be that coming from radium that is on the surface. Anything inside would be trapped there.
As was mentioned earlier there is an epa paper done in conjunction with the National Radon Proficiency Program (NRPP)... (or maybe it was AARST I don't recall) that stated that the primary concern is the air.
You should test the air, and if elevated, then mitigate soil gasses and re-test.
Mark Nahrgang
www.HeyMark.info
Old 5/15/10, 7:16 PM
Brian C. Hoagland Brian C. Hoagland is offline
Any radon inside the granite that was released from decay from radium would undoubtably escape in short order. The question becomes one of degree- if there is in fact enough granite within the structure to appreciably elevate the level within the structure then possibly it could be a concern. But then wouldn't a standard testing protocol indicate that as a problem? Why test the granite only? The only time I could see this as useful would be when other sources of elevated levels were eliminated and there was a whole load of natural stone in the house.
Old 5/17/10, 7:53 PM
Banned
I don't think they're sealed to the particles and radiation emitted by the radioactive uranium, etc. I'm not concerned with radon off gassing and the very small contribution to overall radon levels in a house but with the alpha & beta particles plus gamma radiation that are emitted just at genital level when you're standing at the counter. If there happens to be a hot spot along the edge..........what's happening?
No one seems to have considered this......but when mentioned to a doctor whose house I was at last year.....he screwed up his brow and said "Hmm, never considered that!!"
Some interesting high emissions measurements mentioned in this 2 year old article.
http://www.nytimes.com/2008/07/24/ga...pagewanted=all
Note that EPA and AARST, in their position statements, only talk about radon in the air and not about the particle and gamma emanating from the counters......
http://radiation.custhelp.com/cgi-bi...i=&p_topview=1
http://www.aarst.org/images/AARST_Gr..._8-04-2008.pdf
Old 5/17/10, 9:00 PM
mnahrgang's Avatar
http://radiation.custhelp.com/cgi-bin/radiation.cfg/php/enduser/std_adp.php?p_faqid=5103&p_created=1212758208&p_si d=zSRPl8*j&p_accessibility=0&p_redirect=&p_srch=1& p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3 J0PSZwX3Jvd19jbnQ9MiwyJnBfcHJvZHM9MCZwX2NhdHM9JnBf cHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9Z3Jhbm l0ZQ!!&p_li=&p_topview=1
Brian, if you ever get the chance to play with a Geiger counter, try this little experiment.
Pass it over a granite counter top. It will scare you. Then pass it over a banana.... I'm serious.
You'll laugh your but off over being scared of the counter's particles.
Potassium is a component of granite, and is radioactive and will set off a Geiger counter. Much of the health benefits of a banana comes from the potassium in it.
So all in all, the granite scare is much ado about nothing...
Mark Nahrgang
www.HeyMark.info
Old 5/18/10, 8:17 AM
Michael Larson's Avatar
I read a story a while back about the fact that only a few particular types of granite contain higher levels of decaying particles but I don't have the source anymore. Sorry.
Michael Larson
Hudson, WI
[/I]
Old 5/18/10, 10:30 AM
Michael...
I think you are right. I remember reading that same thing too. Higher concentrations of Radon off gassing may be found in granite specific to, maybe, Brazil.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 5/18/10, 11:03 AM
mnahrgang's Avatar
Originally Posted by jwicklander View Post
Michael...
Jeff
China...
I've heard they test all their granite, and use the good stuff themselves. That which won't meet their own standards is what they export... But of course that is hearsay, and I can't quote the source.
Mark Nahrgang
www.HeyMark.info
Old 5/18/10, 6:06 PM
Banned
Mark:
Why are bananas concentrating radioactive potassium?.......they come from different locations.
BTW, all commercial farm "chemical" fertilizers are marked by their NPK content such as 12-12-12......N-nitrogen; P-phosphorus; K-potassium.
Are we putting rodioactive K on our fields? Is all K radioactive?
Where do you get this information?
Old 5/18/10, 6:13 PM
Bananas Are Radioactive
"It's pretty easy to understand why tile, granite, and kitty litter are radioactive. They contain low levels of minerals that naturally decay. Bananas are radioactive for a similar reason. The fruit contains high levels of potassium. Radioactive K-40 has an isotopic abundance of 0.01% and a half-life of 1.25 billion years. The average banana contains around 450 mg of potassium and will experience about 14 decays each second. It's no big deal. You already have potassium in your body, 0.01% as K-40. You are fine. Your body can handle low levels of radioactivity. The element is essential for proper nutrition. If you have a banana in your car for your lunch you aren't going to set off a Geiger counter. If you carry a produce truck full of them, you might encounter some problems. Ditto for a truck of potatoes or potassium fertilizer."
Michael Larson
Hudson, WI
[/I]
Old 5/18/10, 6:32 PM
mnahrgang's Avatar
Mark:
Q1: A: Don't know, probably
Q2: A: Don't know, not a chemist, but probably.
Q3: A: I got the information by passing a Geiger counter over a banana. (Actually I didn't do it, but I watched it being done.)
Mark Nahrgang
www.HeyMark.info
Old 5/19/10, 9:32 PM
Banned
Have you ever passed a geiger counter over a hot spot in a granite countertop?
If not, we then have no comparison with the little bit of natural background radioactivity in a banana and our bodies. Like I said, I'm not concerned about the radon in air contributions from granite but potential hot spots along a counters edge.
"Granite countertops are the latest trend for
bathrooms and kitchens, but Rice University's
professor William Llope has discovered some
radioactive countertops made out of granite.
Llope says radiation is all around us. It is in the
soil and even in every day household items like
smoke detectors and granite countertops. Most
of them give off harmless amounts of radiation.
Llope calls it a part of the "natural background."
However, he has found high levels of radiation in
some of the granite samples he has collected.
Llope says the radiation doses are hundreds if
not thousands of times the natural background.
He says exposure to these levels of radiation over time can potentially cause cancer."
Radiation is measured in units called millirems (mrems), with the average annual dose per person estimated at 360 mrems or 0.04 mrem per hour. According to tests performed on natural stone countertops by W.J. Llope, associate professor of physics at Rice University's Bonner Nuclear Laboratory, most natural stone countertops emitted radiation "at 0.1 to 0.3 mrem per hour," and were "not a significant risk." However, "a handful of samples" emitted 3 to 4 mrem per hour, a rate "the EPA would consider dangerous assuming long-term exposure and would recommend remediation."
http://www.5min.com/Video/Radioactiv...tops-124973998
Old 5/19/10, 11:11 PM
mnahrgang's Avatar
Yep... Have you seen the videos and read the non-biased university studies about the issue?
I would not attempt to disagree with professor Lope in his assertion that exposure to those levels over time can potentially cause cancer. I believe him. But I don't believe that is the entire story either.
I take what I believe to be a very practical approach to this. A) Most granite is harmless (as stated by your professor). B) No one sleeps on a granite countertop. So your chances of having a "bad" one is small, and even if you do have one, you would have to have prolonged exposure to it to have an affect.
All in all, based on the studies I've read, along with my own deduction, I think this hubub is much ado about nothing.
BTW, I don't pay any attention to the "hype" on either side of the issue. The granite countertop manufactures claim there is nothing to it (obviously biased). On the other side of the issue, most of the articles I've seen claiming the sky is falling, ultimately come from two sources...composite counter top manufacturers, and radon/radiation testing companies. So both sides are biased. I've based my conclusions on some independent university studies that I have read. (and no, since you are about to ask, I don't remember where they were, or what the exact details of them were to quote for you. Sorry.)
Mark Nahrgang
www.HeyMark.info
Washington State Inspectors - Your Deadline Is Near Mike O'Handley Legislation, Licensing & Legal Issues for Inspectors 54 4/14/10 9:15 PM
Radon Testing Kansas City dmoriconi Ancillary Inspection Services & Additional Topics 1 1/11/09 3:11 PM
Radon Class in Oakville and Ottawa mkyriacou Canadian Inspectors 9 2/2/08 11:48 PM
Ottawa to stiffen radon guidelines. gromicko Canadian Inspectors 1 8/16/06 5:28 AM
