FOR IMMEDIATE RELEASE
December 14, 2010 Release #11-067 Firm's Recall Hotline: (855) 239-8324 CPSC Recall Hotline: (800) 638-2772 CPSC Media Contact: (301) 504-7908 Extech Instruments Recalls Digital Clamp and Multimeters due to Electrocution Hazard Description: This recall involves Extech digital clamp meters with model numbers EX612, EX613, EX622 and EX623 and multimeters with model numbers EX540, EX542 and EX570. “Extech” and the model number can be found on the front of the product and the serial number on the rear. Serial numbers that begin with "A" are not included in the recall. ![]()
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
That clamp meter was a waste of money for me.
Does anyone even use the things during routine inspection? Thanks for posting this though. |
I use them all the time. Good way to see if things are operating as intended. Such as an electric pool heater. You can see and hear the fan kick on, but no way to tell if the compressor is working. You would have to sit for a long time to heat the pool. So why not turn it on, place this meter over the wire and see what its pulling. Most of the time it pulls from 19-30 amps. If it pulls only 2-3 amps for a long period of time, the compressor isn't kicking in. I then take a picture when it is or is not operating as intended and place it into my report to either prove #1 it was working or #2 its not working.
So in short, I use one every day. Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Electric pool heater.
You guys just gotta keep rubbing it in all the time . |
Use it all the time to check A/C compressors or any other electrical unit drawing amps or for overloads on circuit breakers.
Florida Licensed Home Inspector HI #36 Certified Master Inspector Palm City, Florida, 34990 772 240 0431 / 954 330 2227 |
Have one in the tool kit which I use a couple times/year. Always good to be able to check amperage if necessary......can tell you nothing's wrong or confirm your suspicions if something seems amiss.
