Mike Hazelwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
I was wondering if anyone is aware of any reference guides that might exist for the dates/yrs. that certain codes went into affect ie. afci 2002, gfci for ext. gar. and baths 1978 and so on, same with plumbing, saftey, hvac, structure, everything.
Any help would be appreciated. Thanks, Mike |
1971 Receptacles within 15 feet of pool walls 1971 All equipment used with storable swimming pools 1973 All outdoor receptacles 1974 Construction Sites 1975 Bathrooms, 120-volt pool lights, and fountain equipment 1978 Garages, spas, and hydro-massage tubs 1978 Outdoor receptacles above 6feet 6inches grade access exempted 1984 Replacement of non-grounding receptacles with no grounding conductor allowed 1984 Pool cover motors 1984 Distance of GFCI protection extended to 20 feet from pool walls 1987 Unfinished basements 1987 Kitchen countertop receptacles within 6 feet of sink 1987 Boathouses 1990 Crawlspaces (with exception for sump pumps or other dedicated equip.) 1993 Wet bar countertops within 6 feet of sink 1993 Any receptacle replaced in an area presently requiring GFCI 1996 All kitchen counters – not just those within 6 feet of sink 1996 All exterior receptacles except dedicated de-icing tape receptacle 1996 Unfinished accessory buildings at or below grade 1999 Exemption for dedicated equipment in crawlspace removed "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Here is a site that lists many state, county, city, townships, etc Building codes.
http://nachinat.com/standards.aspx |
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Need Title 24 (CA) reference for TPR valves | jhugenroth | Plumbing Inspections | 12 | 8/31/09 2:12 PM |
| Good Reference Material? | fnewman | Miscellaneous Discussion for Inspectors | 11 | 8/27/07 11:07 AM |
| Reference guides for Codes? | Mike Hazelwood | Inspection Hardware, Software & Publications | 2 | 2/19/07 3:43 PM |
| Technical Reference Guide Vs Carrier Blue Book | waksell | Inspecting HVAC Systems | 12 | 1/22/07 5:45 PM |
| Reference books question | jclark1 | Inspecting HVAC Systems | 4 | 3/1/06 4:06 PM |
