Old 12/10/09, 7:41 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default REPAIR vs. REPLACE
An inspector in the state of OK inspected a house recently. The water heater tank was identified as an 8 year old Bradford White nat. gas heater.
And the report included this language, "There is a water leak and heavy rust or corrosion on the water connector and fittings of the water heater that will need further evaluation and service by an appropriately qualified specialist."
But the hand-written summary stated, "Corrosion and leak at top of hot water tank (Repair)."
When I evaluate home inspection reports and claims, I notice things like this. The report is written very well by the inspector - using a computer software program. The report identifies a problem (or condition) and makes a recommendation for a professional to further evaluate. Great.
BUT the hand-written summary has "(Repair)" written. And this is the problem.
Long story short - two plumbers further evaluated the tank, the home warranty company denied the claim, and both plumbers recommended a COMPLETE REPLACEMENT of the water heater tank - NOT a REPAIR - as recommended by the inspector in the hand-written summary.
LESSONS LEARNED:
  1. Do not hand-write your reports or summaries. It makes you write some short, quickly worded language such as "(Repair)." Type your report. Better yet use a computer-generated program. Computer-generated reports/documents are superior to hand-written ones.
  2. Be careful when using the terms REPAIR or REPLACEMENT. They mean very different things, and your client will assume that if you say REPAIR, but REPLACEMENT is actually needed - you're going to pay for the difference.
Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America)
Old 12/10/09, 7:53 PM
Bob Elliott's Avatar
Default Re: REPAIR vs. REPLACE
I am not a fan of handwritten checklist style reports but I honestly think the mistake could occur more easily with a computer canned report.
We are all skilled enough to know it needs replacement so you might click the wrong comment by accident, while hand written you must make a mental decision as you write.
Old 12/10/09, 8:23 PM
I never say repair or replace. I use the term "Corrective Action."
"Adverse Condition: The water heater in the utility room is leaking at the supply shut-off valve. The leak is causing rust damage and corrosion to the top of the tank. Recommend Corrective Action by a Qualified Plumber."
I include the definition of the term in my inspection glossary:
Corrective Action: This designates Adverse Conditions for which evaluation by a qualified individual is recommended as soon as possible for any necessary modifications or corrective measures. If, in the process of evaluating and addressing such conditions, it is determined that there are other Adverse Conditions present for which modifications or corrective measures are also deemed necessary, it is recommended that they be addressed at that time. It is further recommended that a copy of the appropriate portion or portions of the inspection report be provided to all qualified individuals retained to evaluate and/or perform modifications or corrective measures to address Adverse Conditions documented in the Inspection Report.
Adverse Condition: A condition determined in accordance with the contractual scope of inspection, which is producing a detrimental effect on systems or components and/or impairing the normally intended function or operation of systems or components.
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared Thermographer®, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 12/10/09, 9:17 PM
Marcel Gratton's Avatar
Kevin
Kevin,
But does the WH needs to be replaced asked the client???
Cheers,
On The Level Inspection
Gatineau, Québec
Old 12/10/09, 9:20 PM
Terry Clayton Terry Clayton is offline
Very nicely written Kevin, Happy holidays
Old 12/10/09, 10:16 PM
Jeffrey R. Pope's Avatar
I have no problem recommending one of the following;
(1) Repair
(2) Replace
(3) Repair or Replace.
and I know how to type it
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/10/09, 11:12 PM
Stephen W. Stanczyk's Avatar
Hmm. Two plumbers chose to recommend complete replacement. That would be $1400 vs. maybe $50 to replace a nipple and flexible supply line. Imagine that. Repair or replace as needed. Budget accordingly.
Stephen Stanczyk
Old 12/10/09, 11:18 PM
Brian E. Kelly's Avatar
Repair or replace fine.
What a shock a "Warranty" Company denied the claim?????
Writing a report and saying "heavy rust" is not clever. Exactly how "heavy" is the rust???
Old 12/10/09, 11:37 PM
I don't have a problem with either verbiage:
"There is a water leak and heavy rust or corrosion on the water connector and fittings of the water heater. Service and correction by a competent and licensed plumbing contractor is recommended."
OR
"There is a water leak and heavy rust or corrosion on the water connector and fittings of the water heater. Have a competent and licensed plumbing contractor service the unit and then repair or replace as needed".
OR
"There is a water leak and heavy rust or corrosion on the water connector and fittings of the water heater that needs service and repair of some type by a competent and licensed plumbing contractor".
OR
The water heater is heavily rusted and fittings are leaking. Have a competent contractor service and repair the unit AS NEEDED".
Old 12/11/09, 1:59 AM
If it is corroded and leaking, does it matter if it is "Heavy"?? Is your "Heavy" the same as someones "Heavy" in another State?
Too subjective for me, best to leave bs adjectives out, IMO.
Old 12/11/09, 2:03 AM
Frank Magdefrau's Avatar
Frank Magdefrau Frank Magdefrau is offline
Kevin
FYI- When writting (reports) you should always speak in "past tense"
The water heater was leaking...
You only use- The water heater is leaking... when you are on-site telling who ever is there you need to inform in person.
Frank Magdefrau
Certified Master Inspector
DeSoto Home Inspection Services
3152 Big Ben S
Hernando, MS 38632
(901) 486-0421
InterNACHI Member since 2002
InterNACHI message board member since 2003
InterNACHI ESOP member from 2004 to 2010
Old 12/11/09, 2:14 AM
Russel Ray's Avatar
LESSONS LEARNED:
I always "recommend repair or replacement." That way I'm covered regardless of what the other professional recommends.
Old 12/11/09, 3:21 AM
Russell Spriggs's Avatar
Russell Spriggs Russell Spriggs is offline
A hand-written summary?
Sounds like a suicide pill!
Verbal summary on site, pending written report, which supercedes all else.
Recommend further evaluation for repair or replacement by licensed contractor.
Old 12/11/09, 12:47 PM
When did it stop leaking?
My reports are written in the "present tense."
The water heater is leaking - and as far as I am concerned, until such time that it is corrected, it is still leaking.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/11/09, 12:49 PM
gbeaumont's Avatar
Ditto
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Make $50.00 More Profit per Inspection with Septic Tanks ebeahm1 Ancillary Inspection Services & Additional Topics 6 8/20/09 2:38 PM
Septic System Care mlarson Ancillary Inspection Services & Additional Topics 49 8/31/07 11:26 PM
Oil Tank Leaking jhagarty Inspecting HVAC Systems 0 6/27/07 5:15 PM
Oil Tank in Basement Bedroom! csteele Inspecting HVAC Systems 15 10/23/06 9:25 AM
Proper Complaint Procedures rcooke Canadian Inspectors 0 8/15/06 11:35 AM
