I saw this hot water heat in the basement yesterday. You can see in the picture that it is mounted inches away from the floor joists and that each joist has burn/drying out marks.
What would you put in the report? I stated that it shows handyman work and can dry out floor joists, cause premature cracking/failure. No signs of failure at this time, but discoloration present showing the this heat is adversely affecting the floor joists. This is not the recommended installation. |
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Fire Hazard.
Since anything that turns wood into toast color can ignite by pyrolysis and the potential for someone to cover it with a drop ceiling or even hang cloths on it could cause a fire.For this reason all fin designed heating must be separated from exposure to floor joist with proper fire proof insulation.This also will prevent heat loss to the void areas between wood floor joist. |
TIm, how hot was the heating system?? I personaly grew up in a home with a baseboard hot water system, and unless they have something set up wrong it should never get that hot. I can see how it could dry out sections of the wood, but it shouldnt hurt anything. Even at 140 deg, its still no hotter then an attic in the summer and that wood seems to do fine right.
My question is why would they mount it that way to begin with. Was it to try and hide the ugly, while still accomplishing heating the home through radiant heat upstairs? Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Hot water heater should not be a fire hazard, However it would not work well there. the joist color is from heat and dust
You have been given three opinions.
One of those opinions is from a Certified Master Inspector. (Wett) wood energy training technician and a teacher of home Inspection. Since we are to look at the worse case scenario this is still a fire hazard. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Radiators are not all that common here but I don't see the fire hazard issue. Radiators are placed close to wood floors and baseboards all the time. I have even seen wood covers over them. People also use them in a retrofit application by attaching them directly to the underside of the floor. I would agree that the staining is a result of the air movement carrying dust. The flash point of wood is 575 degrees and they don't get even close to that temperature. But if there is a required clearance I would like to know for future reference.
This may be a bit far fetched, but please bare with me for a second.
This is presumably in Wisconsin where I would believe that unfinished basements could get pretty cold. Now, seeing as how this discoloration is not limited to the joist and is directly above the heat source....I'm wondering if this could be a discoloring caused by condensation created from the mixture of extreme temperatures at those particular points. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
Mike O'Handley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Fire hazard ?!!!
Seriously? Come on, haven't any of you folks heard of radiant floor heating systems? Those systems are attached directly to the underside of the wood floors and the pipes to the sides of the joists when necessary and I guaranty you they run hotter than those convectors are out there in clear air. There isn't any fire hazard there. You have to make the call, but I don't recommend you declare that a fire hazard. If you do and they are forced to bring in an expert, you're going to end up looking like you don't know what you're talking about. ONE TEAM - ONE FIGHT!!! Mike O'Handley, LHI Wa. Lic. Home Inspector #202 Your Inspector LLC., Kenmore, WA Editor - The Inspector's Journal |
Pyrolysis is defined as chemical decomposition caused by heat. It is the process by which a combustible material exposed to elevated temperatures for a prolonged period of time will dry out, break down and can eventually burn. The chemical breakdown of combustibles situated too close to a heat source is a common cause of fires. Pyrolysis can occur when high intensity heat sources such as fireplaces, solid fuel stoves or fireplace inserts are installed with inadequate clearances. Pyrolysis does not require the presence of a direct flame to ignite; however, it does require specific conditions to occur.
Specific conditions involved in pyrolysis include:
Pyrolysis is a thermochemical decomposition of organic material at elevated temperatures in the absence of oxygen. Pyrolysis typically occurs under pressure and at operating temperatures above 430 °C (800 °F). INSPECTIONLOGOS.COM "I can keep explaining it for you, but I can't understand it for you". Nick G. Monroe Home Inspection |
No fire hazard from my perspective.
The wood discoloration is more likely to be from convection currents rising and depositing dust. You can even see that the deposit is lighter where the pipe is buried in the middle of the fins. I think the installation is amateurish and inefficient but not dangerous. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
just looks like someone is trying to warm the floor above to me...was there a ceramic floor above this area?...sure no fire hazard I see...these Hw fin tubes run behind furniture and below draperies all the time...
He's a master something alright.
| Using your report writer as a marketing tool | sramos | Inspection Hardware, Software & Publications | 3 | 4/17/09 9:24 PM |
| New Report Upload Technology | cdemsky | Miscellaneous Discussion for Inspectors | 49 | 5/1/07 10:19 AM |
