Old 7/31/07, 3:39 PM
jconner jconner is offline
Question Roof Only Inspection?
I have a client that wants me to only inspect his roof. (Outside & in the attic) He is the seller, and is not wanting to get a full pre-listing inspection. Will this cause any kind of issue with any state and/or NACHI standards? (Because I am not inspecting the rest of the house)...
Old 7/31/07, 3:42 PM
tdietrich1's Avatar
Default Re: Roof Only Inspection?
imho,
Sounds too specialized, are you trading into an area where you need to be a licenced roofer?
tom
Old 7/31/07, 3:46 PM
The client pretty much wants the same information about the roof that I would provide in a full inspection, but without inspecting everything else. (Electrical, plumbing, crawlspace, etc.)
Old 7/31/07, 3:49 PM
tdietrich1's Avatar
Sounds like a "Chris Rock" skit.
Go expensive. Meaning a 'specific' inspection 2x your normal rate. He/She might be trying to negotiate you down to like nothing for a simple check.
IMHO,
tom
Old 7/31/07, 3:50 PM
David A. Andersen's Avatar
Just write it in the Inspection Agreement and again in the Inspection Report.
You can contract for anything, so long as all parties agree.
Old 7/31/07, 3:57 PM
rcramer's Avatar
rcramer rcramer is offline
It's just a limited inspection or what I call spot inspections. I do them all the time, the roof seems be of particular concern for most home sellers and buyers. Same standards just one item insted of several. I charge $99 for the roof only. Do a great job and they might hire you for their home inspection when they are buying again. Make the adjustment to the contract and spell it out clearly that the roof is the only thing you are going to look at and all other "normal" items are excluded.
Robert Cramer
Five Star Property Inspections
Your Best & Safest Choice
www.fivestarpi.com
1-877-378-2774
Old 7/31/07, 4:04 PM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by tdietrich1
imho,
tom
Agreed...
Old 7/31/07, 4:08 PM
Dale Duffy's Avatar
I do Roof Inspections Only.....residential $169.00 (2,000 sf)....Commercial at least $399.00 (5,000 sf) and Up.
Wish I could just do Roof Inspections, good money, simple reports.
My agreement is in MS Word, I simply type "ROOF INSPECTION ONLY" in the agreement.
Old 7/31/07, 4:21 PM
Peter C. Russell's Avatar
I do only roofs, like Dale 175.00 for a 20 square roof.
I use Home Gauge so I just delete everything out of the report but the roof and the other necessities.
Old 7/31/07, 4:43 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
I would check with your state's home inspection regulations before doing any specialized inspection work. For instance, here in Pennsylvania, a home inspector can not do an inspection on only one system of the house. I don't know how it is where you are from, but here and high school dropout can be a roofer without anything more than a simple contractor's license and a business license. There are no such things as a licensed roofer here in Pennsylvania. Look into what the laws say and CYA as much as possible.
Old 7/31/07, 4:47 PM
Frank M. Carrio, CMI's Avatar
Frank M. Carrio, CMI Frank M. Carrio, CMI is offline
ESOP Committee Member
James,
"Specific Inspections" such as roof only, HVAC only, electrical only, etc. are done all the time. I would suggest that if you live in a "licensed state" that you check with their standards of practice to see if you are obligated/required to do a "full House/full system" inspection.
If you're not obligated and or required to inspect all of the systems and you are qualified than you are "good to go".
One thing you should consider is that while you are out on the roof is that you could be conducting a "full House inspection" for much more money. In order not to "lose money" I suggest that you charge accordingly. I would charge a rock-bottom minimum of $175.00 for this inspection.
You might find that when you are on the job site that the client might say "oh, while you are here why don't you inspect the this, that, and the other ……. for peanuts".
I have found that the way to get out of this is to say "I'm sorry, I only had you scheduled for one hour and that is what I am charging you for. For these additional components, I can charge our hourly rate or we can add them at increments of $XX.$$ " and then charge your normal rate plus $50 for aggravation.
Signed, Frank Carrio, CMI
Certified Master Inspector & Consultant
Certified, WDI Inspector
Founder & Current President, New Hampshire State Chapter NACHI
NACHI, State Representative for Legislative Affairs
Retired: ICC Certified Member
Retired: Code Compliance Inspector.
Retired: ASTM Committee Member
New Hampshire License #0096
Old 7/31/07, 6:51 PM
Joseph Hagarty,  CMI's Avatar
Originally Posted by sgilligan1
I would check with your state's home inspection regulations before doing any specialized inspection work. For instance, here in Pennsylvania, a home inspector can not do an inspection on only one system of the house...
Scott,
A Home Inspector can conduct single element Inspections in the state of PA. I am not sure where you have interpreted otherwise.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 7/31/07, 7:28 PM
I completely read the law wrong Joe. I don't know how I got that honestly. Here is what I misread from PA Act 114:
"HOME INSPECTION" A noninvasive visual examination of some combination of the mechanical, electrical or plumbing systems or the structural and essential components of a residential dwelling designed to identify material defects in those systems and components and performed for a fee in connection with or preparation for a proposed or possible residential real estate transfer. The term also includes any consultation regarding the property that is represented to be a home inspection or that is described by any confusingly similar term. The term does not include an examination of a single system or component of a residential dwelling such as, for example, its electrical or plumbing system or its roof. The term also does not include an examination that is limited to inspection for or of one or more of the following: wood destroying insects, underground tanks and wells, septic systems, swimming pools and spas, alarm systems, air and water quality, tennis courts and playground equipment, pollutants, toxic chemicals and environmental hazards.
My mistake...I'll fess up.
Thanks for pointing that out to me.
Old 7/31/07, 8:18 PM
John B. Allen John B. Allen is offline
Please Note: John B. Allen is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have no clue where that come from, the law says nothing bout doing anything like this. I am in pa. I think you may have misread. Act 114 ( I believ it is)
I have been doing roofing , or electrical or anything else for ages now. Good cash and easy to do.
Old 7/31/07, 8:34 PM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
read the post above yours .... it was an honest mistake.
James - go for it! I charge $124.00 for a roof (exterior and attic). Great way to sell yourself for a full home inspection when they start looking for an inspector
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 10:50 AM
Cracked shingles pwigle Exterior Inspections 54 4/23/09 11:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
