Old 9/21/08, 4:00 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Default Roof Repair Question
I was cleaning my gutters and noticed when my roof was installed a few years ago they did a poor job of cutting a shingle. The exposed fascia is rotted as it is not sealed.
I was wondering the best way to repair this?
Should I replace the entire shingle?
Cut a small section and use nails and roofing tar to repair.
Just flash the exposed fascia?
Or any other suggestions.
Thanks
Old 9/21/08, 4:16 PM
Michael Larson's Avatar
Default Re: Roof Repair Question
Slide a piece of tin under that last corner shingle and replace the fascia board.
Or consider adding a drip edge to the entire gable end.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 9/21/08, 4:17 PM
James F. McKee's Avatar
David ...what is the overhang up the balance of the Rake...was there a reverse starter row used...and is there a drip edge up the rake????
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 9/21/08, 4:20 PM
Replacing the fascia board would involve removing the gutter, fascia covering.
It is hard to tell how much of the board is rotted. Only the small area is exposed.
Thanks for the reply.
Old 9/21/08, 4:23 PM
The rot is not going away David.
Do it right and it will last decades.
Michael Larson
Hudson, WI
InspectraPro
and
Old 9/21/08, 5:04 PM
Peter Doane's Avatar
Just do what flippers do,... cover, patch, conceal! Then you can add another 100 grand to your home when you sell it!
Or you can do it right and replace it,.. then add rake flashing to protect the fascia.
Peter Doane
NACHI ID# 05120681
Old 9/21/08, 5:40 PM
That is the rake flashing(drip edge) and there was is a starter row used.
I think I will probe the fascia to see how rotted it is.
Old 9/21/08, 6:59 PM
If that is the case and there is shingle overhang of the drip edge the balance of the rake You could work a flashing between the starter row and first row...using plastic roof cement to seal between flashing and both layers...covering the exposed area...i would use no nails here....I would not be at all surprised to find the only rot in that fascia is at the exposed spot and if sealed and flashed would be of no future consequence...jmo...jim
Jim Mckee
Amherst, Ohio
Old 9/21/08, 7:17 PM
Exactly...using metal (shingle color match if possible) you could hem the edges and extend it to the eave of the first shingle covering the exposed wood and angle it back to the bottom edge of the second course and tuck it under that.
Larry Kage, CMI
231 929 3525
Old 9/21/08, 10:24 PM
Carl A. Brown's Avatar
Just think of all the damage that is never seen after it is covered up by aluminum and vinyl siding company's.
Old 9/21/08, 10:33 PM
David P. Valley's Avatar
If the fascia is not badly damaged, then simply slide another shingle under the existing shingle and fasten it. You do this by getting a pry bar and prying up the roofing nails from the underside of the existing shingle. Then get a new shingle and match it up to the existing shingle and cut it to fit/match the existing area. Then slide it under the existing shingle and re-fasten it.
DONE
Old 9/24/08, 12:32 AM
Rodney Dunn Rodney Dunn is offline
I certainly agree with David. No need to go through any extensive repair untill the next time the shingles need to be replaced. Then I would install metal drip edge around entire house.
rod
Old 9/24/08, 2:43 AM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
DONE
Are we going to remove the infection?
Old 9/24/08, 3:12 AM
Brian E. Kelly's Avatar
Mastic
Old 9/24/08, 9:24 AM
Did you not read every detail in my last post? I stated...
Would you like me to tell you how to repair the fascia if it is indeed damaged?
Roof Truss Question jallingham Structural Inspections 7 2/9/09 7:56 PM
Roof question rstufflebeem Exterior Inspections 38 5/8/08 5:28 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Wood shake roof question jclark1 Exterior Inspections 4 9/11/06 10:23 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
